Old 12-29-2024, 03:17 PM   #1
eric8
OEM Pulley Setup
Anyone have a mid to late 70's model C10 that has an original power steering and alternator only belt setup (non a/c)? What I'm trying to find out is if that setup originally had a double groove crank pulley and single groove water pump pulley.
I'm thinking one belt should be routed through the one groove on the crank pulley, over the water pump, and then to the alternator. The other belt i'm thinking goes in the other groove of the crank pulley directly to the power steering pump.
The reason i'm asking is i'm trying to add power steering to an alternator only truck and figuring out what pulleys I need. I've seen some 70's GM cars where both the crank and water pump pulley are double groove, with both the power steering belt and the alternator belts driving the water pump?
eric8 is offline   Reply With Quote
Old 12-30-2024, 11:57 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: OEM Pulley Setup
the crank on mine runs the power steering and then a seperate belt waterpump to crank and alternator
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-01-2025, 02:11 PM   #3
Pontiac1976
Pontiac1976's Avatar
Pic of you motor P/S alt, would help. But a Guess ATL goes crank water pump, P/S goes crank. Crank two grove pulley and water pump single grove pulley P/S single grove pulley.
But if your set up had air pump then it would not be like this.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
