Wiring harness
Kind of a messy question so bear with me. I'm wondering what differences there are between wiring harness for a 67 six cylinder, manual, with no gauges, only lights compared to a 70 350, manual with full tach dash. Can I swap the 70 harness and dash into the 67? For example, is the 67 temp sending unit for dummy lights different than the 70 with gauges? I understand the 70 would have side marker fender lights and 67 would not. Ignition would have accessory on 70 vs 67 that does not. No AC in either truck. What else is different? Thanks for any help.
1967 Chevrolet 1/2 ton 4x4 1972 GMC 1/2 ton 4x4 2005 Chevrolet 1500 4x4 Suburban (302K) 2004 GMC Envoy 4x4 (wife's) 2011 Chevrolet 1500 4x4 Suburban |
Re: Wiring harness
The wires to the sensors, coil, and starter likely will be a different length. The guages use different senders than the dummy light senders. (Dummy light senders are actually switches)
On 67's the front turn signal/parking lights use a 67 (Maybe earlier I don’t know for sure) connector that won't plug in to the 68 and up harnesses. The wiper switch is on different sides of the dash bezel between 67 and 70.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Re: Wiring harness
Can't speak for sure about these trucks, but in most everything GM the plug for a dummy light dash and a gauge dash is the same but a lot of the pin locations are different. I would think if you swapped oil and temp sending units and used all the harness and the dash cluster together then you should be fine.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
![]() ![]() Join Date: Jul 2003
The fuse panel arrangement/mounting is totally different on 1967-68 versus 1969 and later.
1967-68: 1969-72:
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Frame off restored 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 51k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 71k miles, 3.6, 8L45, 3.23 LS, 18" wheels Last edited by 1970cstblazer; 01-03-2025 at 12:01 PM. |
![]() ![]() Join Date: Jan 2005
Re: Wiring harness
The front turn signal light connectors will be different.
![]() Join Date: Jul 2000
Re: Wiring harness
Idiot lights are controlled by switches -- ON when oil pressure is low and OFF when it's OK. Just the opposite for coolant temperature. So you will need oil pressure and temperature "senders" from a 70 truck to drive the analog gauges.
Also you will need to dig into how the ammeter (actually a +/- voltmeter) is connected to the wire running from the battery to the "splice" on the drivers side of the radiator. It's a bit complex to explain. Hopefully you can use the wiring from the 70 truck gauges as-is.
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
Re: Wiring harness
I put a 70 harness in my 67, as others have said there are some differences you’ll have to accommodate but it does work. The things that stand out are: pigtails to the turn signals, engine harness wire lengths, the wiper switch location in the dash, and the ignition switch itself needs to be swapped to the newer style.
EDIT: to answer a couple of your questions directly… I think I just cut the pigtails for the fender markers off. I spliced in the odd 67 connector that runs through the core support to the running lights. Sensors I just swapped out to the correct ones for a “gauges” truck. I assume you’re using the 70 gauge cluster, it should plug right in. I didn’t, my 67 had factory gauges and I reused my cluster, it worked perfectly. I swapped to HEI and internally regulated alternator at the same time so I modded the harness for those. Something about the pinout on the ignition switch is different. The 67 unit will plug in but something didn’t work right (can’t remember what). Just use the newer style switch. Early trucks the fuse box is horizontal, 69+ it’s vertical. It still bolts in just fine without modification, the lettering is upside down though. Posted via Mobile Device Last edited by Cal10; 01-07-2025 at 06:42 PM. |
Re: Wiring harness
Posted via Mobile Device |
![]() Join Date: Sep 2007
Re: Wiring harness
Also one of the biggest issues in using any other year harnessing is 67 is all the plugs. If you look at the males and females you'll notice that (the pigtail blades j mean)
1967custom |
Re: Wiring harness
You may not like my .02 but I would scrap the both of the old harnesses and buy a new aftermarket harness that matches your 67. Again just my .02.
| Bookmarks |
