Leaking Fuel Pump Diaphragm?
My fuel tank is still located in the cab behind the seat and I know that if I disconnect the inlet line from the mechanical block mounted fuel pump the fuel will drain the tank dry without hesitation.
My question is that if the mechanical fuel pump diaphragm were to rupture or crack sometime due to age or something would it be possible for raw fuel to find its way into the crankcase? |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
Re: Leaking Fuel Pump Diaphragm?
Yup. Fuel can flow until the level in the engine is the same as the level in the tank.
That is scary!
![]() I might drive my truck every few days now that I'm retired and it's embarrassing to have to crank the engine over for 20-30 seconds every time before it finally starts using today's fuel. ![]() So I've decided to eliminate that problem by deleting the mechanical pump and replacing it with an electric. Yea this pump is probably overkill but those selinoid pumps sound like a friggin' jackhammer. ![]() Thank you for the reply and Happy New Year!
You're welcome! I have an electric fuel pump that my FiL put on. He did it because he would run a saddle tank dry and the switch tanks. The electric pump got fuel to the engine sooner. It is a solenoid type, and yes, it's a real clacker. I do use it if the truck hasn't been started for a few days.
Going to electric I would put an oil sender safety cutout on it or an inertia switch .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
I totally agree with you on that suggestion (thank you
)although an oil pressure switch would probably put me back in the same hard start boat I'm already in.If I get hit hard enough to rupture a fuel line or even the in-cab tank itself, the fuel isn't going to need any help spilling everywhere. There's something to say about peace of mind though. Standard Motor Products FV-7 Fuel Pump Cut-Off Switch Assorted, One Size https://a.co/d/7eUrqhi |
#7 | |
Still plays with trucks
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
My cousin had a fuel pump diaphragm leak into his engine while it was running and fill up his crank case. It worked just enough that the engine still ran but still leaked fuel into the engine. It diluted the oil down so much that it trashed the bearings in no time flat. We ended up having to put a different crank and cam into it because the journals and lobes were so torn up. This happened in one days commute to work on the highway about 30 miles round trip.
#10 | |
It was but I quickly discovered that I need to fabricate a tin heat shield because of the close proximity of the exhaust pipe. Other than that it ran great and fired right up after sitting for so long.
Hope your hearing is bad and you won’t hear that constant loud buzz from the pump.
You can reduce it by using some 1/2 inch thick rubber between the bracket and the frame. |
I'll never hear it.
BOOM BOOM BOOM whirrr
#15 |
...ok so what the heck is this supposed to shrink around?
#16 | |
Really not that bad if you consider the fact that some people pay good money for a noisy Pete Jackson gear drive. ![]() Much more leak testing and cleanup before I take a test drive to determine if I need a regulator or not but I think I'm going to be happy with it in the end.
#17 |
You’ll still hear it!
And the kicker is it won’t change your starting problem. |
#18 |
You have no idea how loud I crank my stereo and it will refill my float bowls before I turn the key so yes it will fix the fuel evaporation issue and start the engine right up.
And I'll stop worrying about a crankcase full of gasoline when the mechanical fuel pump diaphragm finally fails. You sound like a geezer.
#19 |
So what’s the pressure output on that pump?
#20 |
Good question, I think it's low enough to not require a regulator but...
Carter Electric Fuel Pump https://a.co/d/3nUCTlr It's supposed to be quiet but if not I'll just tell everybody it's feeding duel 4 barrels and leave the hood down.
#21 |
![]() Join Date: Jan 2025
Can someone explain the electric fuel pumps to me like I am a 3rd grader. Are they connected to a relay and the ignition so that is how they come on and what keeps it from just flooding the carb if you turn just the ignition or a pumps switch on.
1972 C10 Custom Deluxe Highlander 402 Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility. |
#22 | |
Wiring that stuff up under the dash was another adventure. ![]() Love it LockDoc, I'll look into the heavy duty version. ![]() My Sister got me one of those flashlights that clip to the bill of a baseball cap and I don't know how I ever lived without one. The bill kept bumping into everything though so I broke out the scissors.
#23 |
![]() Join Date: Apr 2016
The carb does not get flooded with an electric fuel pump or mechanical fuel pump because the carburetor has a float in a bowl connected to a needle and seat valve that shuts off the incoming supply of fuel. Pretty much just like a toilet tank shuts off incoming water when the tank is full. If that piece is working correctly, the carburetor only lets in enough gas to fill the internal bowl. The needle and seat and sometimes the float are some of the items typically replaced during a carburetor rebuild.
#24 | |
#25 |
| Bookmarks |
