![]() Join Date: Nov 2024
Lift kit for 2wd
Full Circle Fabrications “BOLT” on long travel suspension kit specifically designed for 67-72 Chevy trucks. Finally a suspension kit that doesn’t put you on the ground! This was designed for functionality but looks great too. It’s 3” wider per side and has 12.5”+ of useable wheel travel using 8” travel coil overs, all while keeping your stock steering!
Kit includes: -upper and lower control arms (powder coated) -mounting plates -Grade 8 mounting hardware -spindles -heims and uniballs -steering ujoints and dd steering shaft -extended steering arms Kits priced at $3800 More information at fullcirclefabrications.com |
| Bookmarks |
| Tags |
| c10, lift, lift kit, long travel, off road |
