Yesterday, 06:33 PM | #1 |
Junior Member
Engine Crossmember?
This is the engine crossmember that came in my 1966 GMC Suburban 4WD. Is it stock? The top two bolts on each side were bolted to the upper frame rail but the bottom holes did not line up and the were tack welded to the lower frame rails. I’m trying to make sure I have an original crossmember and go from there as I am going to attempt to put an LS motor in. Is there a better way to go about that swap?
1964 Chevy Suburban 4x4 1966 GMC Suburban 4x4 |
