Old 01-24-2025, 01:11 AM   #1
docrock
docrock's Avatar
1988 Alternator wiring
I installed a TBI 5.7 out of an 88 van in my 42 Chevy truck. The install is going well and running. There are 3 wires, one is a larger red and goes to battery. The brown wire comes from the connector at the alternator goes to a dash light and then a wire goes to the on position on the ignition switch. The wire in question is a pink with a black line, where does it go?
Thanks for any help
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344
1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494
R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438
1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250
docrock is offline   Reply With Quote
Old 01-24-2025, 04:21 PM   #2
sntrym95
sntrym95's Avatar
Re: 1988 Alternator wiring
https://www.hotrodders.com/threads/1...r-wire.167433/
Mike
sntrym95 is offline   Reply With Quote
Old 01-24-2025, 05:35 PM   #3
Second Series
Second Series's Avatar
I was looking at your build the other day. I used an '88 GMC for my '47. Pictures of the alternator hook up in my build thread pg.6 #141. Just the Two wires, but you might want to add a resistor across the dash light.
'47 Panel to '88 K2500 Frame Swap
Mechanical Speedometer Drive Solution
1947.2 1 ton Chevy Panel
1955.2 Chevy 6700 Bus/RV
1990 Chevy K1500
Second Series is offline   Reply With Quote
Old 01-25-2025, 06:49 PM   #4
docrock
docrock's Avatar
Thank you both with your replies. That was a lot of reading on hotrodders and your build page. From what I gather, it seems I only need the brown wire that I have hooked up to the light and ignition. the pink and black wire is not really needed.
