01-26-2025, 02:19 PM | #1 |
Pertronix 1181 stock 72 350
In the process of installing a pertronix 1181 in a stock 72 350. Directions mention with or without ballast resistor. I don’t see a ballast resistor. Believe it has a resistance wire instead. Would I just wire up as if it doesn’t have a ballast? Also has a condenser on the points set, but also another on the coil bracket. Would I keep this or eliminate it. Lastly has a stock 293 coil. Am I ok to keep using that?
01-26-2025, 02:22 PM | #2 |
Re: Pertronix 1181 stock 72 350
I've had a 1181 set on my Chevelle for 25 years and have never had a problem. Car has a resistor wire. The point set goes away entirely (kind of the whole point of the Pertronix set up). Keep the condenser on the coil, helps keep radio buzz from happening. Be sure to shim the distributor shaft per the instructions if the distributor is worn and has a lot if up and down movement on the shaft.
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings |
01-26-2025, 09:45 PM | #3 | |
01-26-2025, 09:54 PM | #4 |
The vacuum advance not working is going to make your fuel mileage suffer as well as give you a small vacuum leak.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-26-2025, 09:51 PM | #5 |
The Pertronix will work fine with the factory coil and ballast resistor. You just need to supply it with 12v.
If you refer to fig 3 in the instructions it shows positive 12v power to the unit being hooked to the ignition switch side of the ballast resistor. We have a ballast wire instead of a resistor. Hooking the unit to the ballast wire will only provide it 8-9 volts which isn't enough for the unit to operate properly. This means you will need to find a different 12v positive supply from the ignition switch. That provides power in the run and start positions from the ignition switch. Or hook the 12v positive supply to the Pertronix to the ballast wire where it exits the connector on the firewall. Or remove the ballast wire and replace it with regular wire and replace the factory coil with one that works without any ballast wire or resistor. And hook the unit to the 12v supply at the coil. That is how mine is hooked up on my Burban.
Yesterday, 11:45 AM | #6 |
Yesterday, 01:51 PM | #7 |
The black wire on the 1181 connects to the negative (-) terminal on the coil.
Don't connect the red wire to the positive side of the coil as this terminal is powered via a resistor wire and supplies reduced voltage to the coil. The red wire needs a full switched 12V ignition source. The pink wire on the fuse panel is a great place to power up the 1181. The reduced voltage is fine for the coil but the 1181 module needs a full 12V. |
Yesterday, 02:11 PM | #8 | |
Yesterday, 02:17 PM | #9 |
The large pink wire that runs to the idle stop solenoid is also a good switched 12V source.
Yesterday, 05:36 PM | #10 | |
Yesterday, 01:52 PM | #11 |
No. The ballast wire acts as a resistor and causes the voltage to drop down to the 8-9 volt range which is too low for the Pertronix.
To see this check the voltage at the positive terminal of the oil when the engine is running. The ballast wire on our trucks starts at the firewall terminal and goes to the coil. It is the cloth sheathed wire pointed out in the photo.
Yesterday, 02:53 PM | #12 |
The resistance in the wire supplying voltage to the distributor changes with length. I cut the resistance about an inch long at the firewall plug and soldered a wire to it. Everything stays the same that way, including the factory fusing and switching. I couldn't even measure the voltage drop that way.
When I change to an HEI I do the power supply the same way. It has worked out well over the years. Cheers |
Yesterday, 03:09 PM | #13 |
For those of you keeping score at home....
1970 C10 Custom longbed 350/350 Code:
__ ______|__]\____ ....|___(o)_____(o)_] |
Yesterday, 08:38 PM | #14 |
Bingo. I've had my 1181 connected to a resistor wire for 25 years and have never had a problem.
To the OP: Yes, you need a properly functioning vacuum advance. Two additional comments on vacuum advance: 1. Works best connected to manifold vacuum instead of ported vacuum and 2. Not all vacuum cans are the same, make sure you get the proper one for your particular application. Depends on the vacuum signal your engine makes at idle and full throttle.
