Old 01-28-2025, 09:17 AM   #1
jollymon02
Junior Member
Hood alignment
Done some searching and can't find anything definitive to this problem, so reaching out on our 1972 GMC hood gap.
I think I have validated we have the right year fenders, cowl, and hood (OEM) upper grille, and hood (aftermarket), but I still have this gap. No excessive panel gaps from fender to doors. What advice or measurements do you have to assist with minimizing this gap?
jollymon02 is offline   Reply With Quote
Old 01-28-2025, 10:21 AM   #2
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Hood alignment
You can move it back slightly by loosing the upper hinge bolts. As for the height, the rear rubber seal if hard wont allow the hood to sit flush. Only seal worth a hoot is an NOS GM seal, as they have the correct rubber density, and proper shape.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 01-28-2025, 10:48 AM   #3
jollymon02
Junior Member
Re: Hood alignment
If I move it back, then I have a gap up front, which is the premise of the post. There is too much space. Anyone got a link to the OEM hood rubber?
Old 01-28-2025, 11:06 AM   #4
1970cstblazer
Re: Hood alignment
Can't really tell, but the front edge of the hood, how does it line up with the front edge of the fender?
Old 01-28-2025, 11:08 AM   #5
1970cstblazer
Re: Hood alignment
GM 6270848
https://www.ebay.com/itm/36536788889...Bk9SR7SumdeVZQ
Old 01-28-2025, 12:33 PM   #6
A1971Blazer
A1971Blazer's Avatar
Re: Hood alignment
You may have to fudge the cowl forward slightly and the hood back slightly and kinda split the difference. I think the factory tolerance was 3/16" ±.030 so they didn't really fit perfectly from the factory. I had to fudge my hood back about 1/32 but it's not that noticeable.
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is online now   Reply With Quote
Old 01-28-2025, 03:17 PM   #7
pjmoreland
pjmoreland's Avatar
Re: Hood alignment
If you can adjust the doors back, then you can move the entire front clip back, too, which will decrease that hood/cowl gap.
pjmoreland is online now   Reply With Quote
Old Today, 11:38 AM   #8
Sheepdip
Sheepdip's Avatar
Re: Hood alignment
A couple of years ago I installed new cab mounts on Otis and it basically threw everything out of whack so to speak, the radiator supports were new.
It still boggles my mind as to why someone would dismantle a truck to paint it then put the old worn, possibly original cab mounts back on.
I took it to a local guy who's been around for years and works wonders on these old vehicles, he did end up moving/adjusting the doors on both sides to get everything to fall into place.
Sheepdip is offline   Reply With Quote
Old 01-28-2025, 09:21 PM   #9
jollymon02
Junior Member
Re: Hood alignment
Thanks for all the suggestions. I will check all of these.
Old Yesterday, 09:38 PM   #10
Richard
Re: Hood alignment
Looks a little high in the back as well. Loosen the three bolts on each side holding hinges to fenders. Push up on front edge of hood, use a prop rod or have someone hold it while tightening hinge bolts. Should lower back of hood and suck it a bit tighter to cowl.
Richard
