Old 02-07-2025, 11:04 AM   #1
Michael D
Active Member
dash pads
It looks like one of the top screws popped where it is molded into the pad right in front or behind the steering wheel so I get to look at it every time I drive.
My question is which supplier or board member for that matter makes and sells a good quality pad? Any recommendations?
Michael D is offline   Reply With Quote
Old 02-07-2025, 11:28 AM   #2
kaycee
kaycee's Avatar
Re: dash pads
Classic Heartbeat is good
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 02-07-2025, 07:35 PM   #3
Orefactory4x4 swb
Re: dash pads
I picked one up from summit for like 70.00 worked good
Orefactory4x4 swb is offline   Reply With Quote
Old 02-07-2025, 07:59 PM   #4
pjmoreland
pjmoreland's Avatar
Re: dash pads
I installed a Dashes Direct pad in my '71 last night. It's a little wavy along the front edge, but I'm satisfied with it considering the price, and it's made in the USA. There are a couple photos of it in post #424 here:
http://67-72chevytrucks.com/vboard/s...854269&page=17
Summit:
https://www.summitracing.com/parts/UDD-D10016700
pjmoreland is offline   Reply With Quote
Old 02-12-2025, 07:49 PM   #5
FoodStamp
Re: dash pads
I also did a dashes direct pad but ordered from summit racing which was half the price. These from summit could be old stock or blemish ones they have of the end of the batch as I also have low spots where the mounting studs are when tightening down. Speculation only on that.
It fit great like it should but Its cold here right now and i have loosened the nuts some what to see if when it gets hot if the pad will settle correctly. Great pad and i got the i think last Green one from summit. It doesnt look bad at all, I think we can agree the best we can settle on is whats reproduced at the moment.
FoodStamp is offline   Reply With Quote
Old 02-12-2025, 09:49 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Re: dash pads
Yes, it is recommended to not tighten down the nuts all the way, just snug.
Leon
Old 02-12-2025, 09:47 PM   #7
LockDoc
LockDoc's Avatar
Re: dash pads
Is there a nut on the stud? If not try putting one on it and see if it pulls it down. It should. If there is one there, try tightening it down some.
Leon
