Lower radiator hose
Getting ready to install a new champion radiator in my 70 gmc c1500. I figured out the top hose but having some issues with the lower. I see there are 2 options 1 with factory ac vs non ac. Mine was originally a non ac truck i believe but someone added classic air and switched to a later 1 piece seal block. I am looking at whats in the truck now but looks like it might not be right. Right now it looks like its a non ac hose (gates 20582) but the fit looks sketchy at best. Wondering if anyone knows a better hose to run.
![]() Join Date: Feb 2022
Re: Lower radiator hose
Touching the frame will cut the hose in no time. Try rotating just one end or even both of the hose. You might get it off the frame. The hose is a cut to fit and may be too short
I just remember having a heck of a time finding a hose that would even remotely work because of how far back my engine sits, but putting a piece of fuel line on the frame made me feel better about the rubbing issue.
![]() Join Date: Jun 2005
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Oh yea I've got some post or thread on this forum somewhere concerning the lower radiator hose but I don't know how to find it.
My engine sits back with the IL-6 frame mounts so that didn't help and I wound up double clamping the hose to the radiator after someone suggested I may have to trim it, which helped. At any rate no matter what you end up doing I would suggest you cut a slit along a piece of fuel line to protect the hose from chafing against the frame. I got those things all over the place and it helps me sleep better at night. ![]() |
Thanks for the info. Ordered a 20694 for ac trucks. Will see if its fits better. Hopefully changing out the parts tomorrow if the weather holds out.
