![]() Join Date: Jan 2025
Location: Clarkdale, Arizona in a van down by the river
Do rear leaf springs make my truck a heavy 1/2 ton?
I guess I could check the door decal for the load rating if there is such a thing. It is the Custom Deluxe model and the glovebox sticker says it came with the rear leaf. Does the heavy indicate anything other than leaf springs and a higher load rating?
'72 C10 / 402 ___________________________________________ Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility. |
All about them K’s
![]() Join Date: Jun 2014
Re: Do rear leaf springs make my truck a heavy 1/2 ton?
Does it actually mention heavy springs or just rear leaf spring equipment(or similar)?More than likely it just means your truck was ordered with leaves instead of coils. HD rear spring equipment or similar is the call out for the higher capacity springs. The whole “Heavy half” thing was a promotional thing with the square body trucks. The 67-72’s could be had with upgraded springs front and rear on both 2 and 4 wheel drive trucks, but I don’t think it actually changed the GVW of the trucks. Someone may correct me if I’m wrong. My K20 had the hd springs front and rear but still has the 7600 GVW all the other K20’s I’ve ever seen have.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
Who Changed This?
![]() Join Date: Jan 2013
If it doesn't say any G## codes other than G70 for optional leaf springs, it isn't heavy duty. You can look up the option codes here-- G## is all the rear spring stuff.
https://outintheshop.com/options.html
#4 | |
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
![]() ![]() Join Date: Jul 2002
Heavy halfs did not exist back then. Just a (much) later marketing term. You could get HD coil springs or leafs on our trucks. MY old 70 SWB stepside had the HD springs (coil) option. My current 70 has the overload leaf option.
Active Member
![]() Join Date: Mar 2022
How many leafs came standard for a half-ton? My ‘67 shortbox with a I6 has a stack of 8. Seems excessive…..
After typing 4 paragraphs, the server said “too busy” and I lost it all. FML
67-68 in 4 wheel drive had different leafs than 69-72, so assuming the same for 2x4 I can’t answer that question. 69-72 C10 had 4 leaf spring base and 5 leaf as HD. My 69 C10 short step is an HD equipped leaf spring truck. Most Chevy’s were coil and most GMC were leaf, but I have a leaf C10 and a coil C1500 so you don’t know. The “Heavy Half” allowed GM to avoid emisssions equipping vehicles over 6500# in the 75-78 time (at least I think that was the number….) it was more of a “badge engineering” move than anything else. The government changed those numbers not long after and that was the end of the higher GVWR 1/2 tons. I think that number moved to 7500# next and then 8000#? My ‘85 C2500 came without catalytic converter even. It’s 8200# GVWR.
I saw a few GMC trucks and others listed in Utah with numbers on the side, like UT6500, so I assume that was for the UT DOT and weight licensing classification.
Chevy's came standard with coil springs, GMC's came standard with leaf springs. You could order a Chevy with leaf springs, or a GMC with coil springs.
It seems like you have a Chevy with leaf springs, aka the same as the standard duty GMC 1/2 ton leaf springs.
1970 ![]() 2016 GMC Sierra K1500 https://67-72chevytrucks.com/vboard/...d.php?t=857044 |
