Old Today, 03:04 PM   #1
Ironhorse
Ironhorse's Avatar
4 x 4 Straight Drop Exhaust - Pair
Up for sale is a full set of the straight drop, center dump 4x4 exhaust manifolds. Manifolds have NO cracks, splits or chips. Normal cast iron surface but can be smoothed if one desires. Original GM, not cheap overseas knock-offs. Pre A.I.R. molds with no smog tube holes. Complete with the exhaust collector rings for each side and if needed, the right side cast iron carb heat collector is included. Was used as a spacer only as the center flap valve has been removed. All six exhaust studs are straight and very usable after running a thread die on each stud. $100 to your door with flat rate Priority Insured shipping, money order payment, do not have Paypal.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is online now   Reply With Quote
Old Today, 03:43 PM   #2
72Cheyenne454
72Cheyenne454's Avatar
Re: 4 x 4 Straight Drop Exhaust - Pair
Interested in these. Can you post pictures of the top of both manifolds please.
Thanks,
Miles
72Cheyenne454 is offline   Reply With Quote
Old Today, 04:05 PM   #3
Ironhorse
Ironhorse's Avatar
Thanks,
Miles
Miles, how do you want the pic? Looking straight down with the manifolds against each other? What particular angle or straight on look are you wanting? Looking at the manifolds as they mount to the engine block? Let me know and thanks for the interest.
Wellington, Ks
Old Today, 09:03 PM   #4
Ironhorse
Ironhorse's Avatar
Miles, not sure what you were wanting to see but here are a couple ''top'' pics of each manifold. One manifold has the hot air take off tube for the afore mentioned manifold heat for carb choke. Intact and solid, can be easily plugged if not needed or used as was intended originally. Let me know if these pics show what you wanted and thanks for your interest.
Wellington, Ks
