Rear Brake Questions
Hi guys,
I'm deep into a full rebuild of the brakes on my 69 C-20. New everything from the booster to the cylinders - lines, hoses, all of it. The fronts are rebuilt and everything went fine there. Got to the rears and the driver rear was all oily inside the drum when I took it off. I'm assuming that this is because the oil seal on the inside of the wheel hub failed. Can someone confirm that's the most likely cause? I know that oil can get around the threads on the axle bolts also, and plan to use thread sealant on those when they go back. If it is the seal, can those be replaced without disturbing the preloaded bearings in the hub? It looks like they are on the outside and will just pop out with a seal puller. Thanks! -Wes
Found Grandpa's old '69 Chevy C-20 - It'll never leave the family again. "For just a little more, you can do it yourself!" |
![]() Join Date: Jun 2005
Re: Rear Brake Questions
That seal looks like it is damaged. That is the most likely cause of the gear lube in the brake drum.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
| Bookmarks |
