Is there a diagram for the window switch itself?
I have been looking through google images, but I can't seem to come up with a wiring diagram for the driver's power window switch. It's the one that has two switches and is a rectangle not a square.
There's lots of diagrams for the whole door including the electric motor and other things. But I hoping someone knows where to find one that showed what each color is, going to the power window switch. The truck is an 87 model if that helps. Hopefully the wire colors are the same on all the 80's trucks. thank you |
Re: Is there a diagram for the window switch itself?
I did find this one, but I'm bad at reading electrical schematics. It looks to be for wiring up the relay mod.
Are the colors going to the switch still accurate? They're the right colors and match the wires on the truck, but I'm not sure if they moved anything around. Hopefully each pin on the switch still matches each corresponding A, B, C, D, E, F down below. |
| Bookmarks |
