Old 11-15-2025, 02:52 PM   #1
eric8
OEM Ignition/Door keys
Being one to obsess over genuine OEM details when it comes to my 77 C10, my next quest is to find the proper NOS ignition and door key. All I have are the Ace Hardware versions.
Based on my research, I need an E and H coded key for the ignition and door (GM# 1154606 & 1154607, respectively). Looking at GM parts catalogs, it seems GM changed these key codes every 4 years? For instance, E and H blanks are for 69, 73, 77, and 81 model years.
This of course piqued my curiosity. Even though every GM key blank looks the same, I assume there are subtle differences that won’t let a 1976 key blank be cut to fit a 1977 ignition?
Can anyone shed light how this works? Yes it’s mainly me nerding out for my own curiosity.
eric8 is offline   Reply With Quote
Old 11-15-2025, 05:07 PM   #2
ron350
ron350's Avatar
Re: OEM Ignition/Door keys
The long groves and ridges are different from one lettered key to another lettered key.
Like your E key can't be inserted in6to a H keyway.
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is offline   Reply With Quote
Old 11-16-2025, 12:09 AM   #3
eric8
That makes sense and seemed to be the conclusion I had reached. Only thing that confused me is that when I had a spare ignition key made it seemed like they were “oh you have the classic square head GM key” and just quickly grabbed the GM shape blank off the rack. I don’t recall them looking at key codes etc but maybe they were doing more behind the scenes than I saw.
Old 11-16-2025, 10:28 AM   #4
Dead Parrot
Years ago for college money, I worked in a discount store that made keys. After a while, you knew which 2 or 3 key blanks to check and then match the ends. No lookup needed.
Thanks LockDoc for the info. Saved for future reference. My 75 is one that has a swapped ignition. Now has a E key. Doors are still the B key.
Dead Parrot is offline   Reply With Quote
Old 11-16-2025, 12:19 AM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Before 1973 the pickups came from the factory with one key profile that worked the doors and ignition. That changed in '73 when GM started using the two key system. The key profiles changed every year up to about 1983 but repeated every few years.
Here is what I came up with. One thing you have to remember is that over the years part numbers change.
The key blanks will only fit the locks they were designed for. (Except).... Gm supplied Universal door and ignition locks for almost all vehicles. Universal locks would accept any key profile and were less secure. The reason they did this was so that the dealers and locksmiths wouldn't have to carry all of the different locks. They could have one door lock or ignition lock on hand that would fit many different vehicles..... Also remember that the lock cylinders themselves were interchangeable between years ('73-'78 & '79-'87) so you may find any key profile lock cylinder in any truck.
I didn't have a lot of time to put this together so if anyone sees any glaring errors please let me know.
1973 Ignition:
Key: Groove 56, "E" Keyway
Original GM Key Blank # 7025014
Cross Reference to other brands of blanks: 320404
1973 Doors:
Key: Groove 57, "H" Keyway
Original GM Key Blank # 7025019
Cross Reference to other brands of blanks: 320405
1974 Ignition:
Key: Groove 58, "J" Keyway
Original GM Key Blank # 7025282
Cross Reference to other brands of blanks: 320470
1974 Doors:
Key: Groove 58, "K" Keyway
Original GM Key Blank # 7025288
Cross Reference to other brands of blanks: 320471
1975 Ignition:
Key: Groove 50, "A" Keyway
Original GM Key Blank # 7027275
Cross Reference to other brands of blanks: 320588
1975 Doors:
Key: Groove 51, "B" Keyway
Original GM Key Blank # 7027281
Cross Reference to other brands of blanks: 320589
1976 Ignition:
Key: Groove 54, "C" Keyway
Cross Reference to other brands of blanks: 320652
1976 Doors:
Key: Groove 55, "D" Keyway
Cross Reference to other brands of blanks: 320653
1977 Ignition:
1977 Doors:
1978 Ignition:
1978 Doors:
1979 Ignition:
1979 Doors:
1980 Ignition:
1980 Doors:
1981 Ignition:
1981 Doors:
1982 Ignition:
1982 Doors:
1983 Ignition:
1983 Doors:
1984 Ignition:
1984 Doors:
1985 Ignition:
1985 Doors:
1986 Ignition:
1986 Doors:
1987 Ignition:
1987 Doors:
Leon
Old 11-16-2025, 05:42 PM   #6
eric8
Thank you for compiling this info. My current keys are Ilco branded and have part numbers B44 and B45, which cross over to the correct E and H lock codes for my model year, so looks like I have all original locks.
More nerd info:
The original GM parts book lists a 'B&S number' of 320404 and 320405 for an E and H key code set. The B&S number apparently stands for Briggs and Stratton. I'm assuming of the small engine builder variety?
Old 11-17-2025, 12:10 PM   #7
LockDoc
LockDoc's Avatar
No problem. I posted the info for the '67-'72 trucks a few years ago.
https://67-72chevytrucks.com/vboard/...d.php?t=246485
More nerd info:
Yes, Briggs & Stratton supplied the locks and keys for GM (and many others) since about 1920, They were bought out by Strattec who still supplies locks and keys for the auto industry.
Leon
