53 stock column,electric P/S, 1:1.5 steering quickener, 15" wheel
In my 53 3100 I'm using the stock column. I'm using the 57-59 steering wheel so I can get the factory self cancelling turn signals and incorporate my Dakota Digital cruize control switch. I put a 15.5" ring on the 57-59 wheel and restored it with PC-7 epoxy. I installed a Howe 1:1.5 steering quickener. That brings my steering ratio from the stock 22:1 to a modern 14.6:1. 4.5 turns lock to lock. I installed EPAS Performance model specific electric power steering with adjustable gain. I rebuilt the stock box. I used 2k primer, jet black base and clear. I replaced all the bolts with ARP polished stainless 12 point bolts because I'm weird. Not much resistance with no power. If it fails it just goes to normal. I'm happy with it. I put this unit without the quickener on a friends truck several years ago and it's still working fine. It's a model specific kit so everything fits without adapting something from another application. No P/S box , pumps, hoses, belts or pulleys for me. I like a clean engine compartment. I also have an electric A/C compressor from down under with Old Air inside kit.
Re: 53 stock column,electric P/S, 1:1.5 steering quickener, 15" wheel
Will the electric power assist be under the dash or in the engine area?
Looks awesome my man. Great work. |
It tucks up under the dash pretty nice. The quickener has a 1/4" offset in it. I offset it upward and was able to take that out of the stock mount. It torques off the column and requires no mounting to the truck so you can clock it. Sorry about the small tear in the seat
looks good.
a little vinyl repair glue and possibly adding a little stuffing for comfort and the seat is back.......lol |
also, I think your defrost tube has become disconnected from the heater......
Very neat mate, forgive the stupid question but whats the pedal on the far left ? Emergency brake ????
It always seems impossible until it's done |
Accel in middle
Brake next Clutch next Elect switch on floor is high low Bea. Switch. About an inch round Park brake next, if equipped. On a modern truck 55-59 had a hand operated park brake below the steering columnn. if your truck has an extra pedal there it was probably a retro fit from something else 55-59 Chevrolet truck factory assembly manual Pick the trifive site Free download Shows all that stuff |
#10 | |
Sorry, I was thinking I was on a different thread. That's why the run down on task force era.
Doh!
I'm not using my stomp starter but I'm thinking about hooking a switch to it so it looks like it works.
ooooo cross flow head on a 292!? Dry sump? Supercharger? t56? show us more about that!
I'm midway through swapping in a refreshed 292 for the tired 250 in my '52. Just stock though Stomp starter is definitely an oddity these days, my son preserved it on his DD 46 sedan. 6 foot controls in that one. 7 is possible I remember a vehicle from my youth that had a foot activated wiper pulse switch attached to a metal ring with a rubber squeeze bulb pump for the washer fluid in the center. Can't recall what that was on, or find pictures. Anyone else recall those? edit: foot pump/switch was on early '70s ford capri Last edited by leegreen; 12-18-2025 at 05:18 PM. |
#15 | |
#16 |
wow, totally awsome
when I saw post 13, I was going to suggest "that valve cover would look cool polished", but I held back, unwanted suggestions and all that. |
#17 |
That's funny you would say that. I live in Northern Indiana and it's crappy here now. I am right now setting up my coffee table to polish the valve cover and the outside of the head. I haven't decided if I want to engrave something on the flat top of the valve cover. I'm clearly single. I polish everything. I call it micro-aerodynamics.
#18 |
That is one awesome engine right there
![]() ![]() ![]() I am a 6 cylinder guy too, I have a blown injected 202C.I. in one of my other cars - would have been way cheaper and easier to go V8 but everyone does that ..........
#19 |
I understand completely. This is for my 53 Chevy 1/2 ton pickup Drag and Drive build in the crowded 8.50 second class in the quarter mile. Just imagine the smile on my face when I beat the twin turbo big blocks with my little straight six and an old school blower and carbs. This thing is going to weigh maybe 500 pounds with the 100 pound blower.
#20 |
![]() Join Date: Feb 2022
Mick53 your truck's whole drivetran looks bad to the bone buddy!
Your straight 6 is a thing for the eye to behold!!! May have to run the 53' with the hood off
1955.1 GMC 100 RestOMod 1972 T120RV 1967 C200 Trail 90 2014 TRD Quad CAB |
#21 |
I'd like to see this truck in the build section. Is that possible?
#22 |
| Bookmarks |
