Old 12-17-2025, 01:05 AM   #1
K10-Kansas
K10-Kansas's Avatar
Engine temp sending unit backwards?
***EDIT*** I had my multimeter on the wrong setting so I uploaded new pictures and retyped the post to avoid confusion.
My sending unit is showing 128 ohms when the engine is 228 degrees. Davepl posted a good chart showing that at that temp I should be getting 65 or 70 ohms. What ohm rating are you getting when fully warmed up and if your sender is working well, where did you get it from?
1971 C10 body. 76 4x4 chassis cut to short frame. Crate 350 2nd Gen small block. 4BBL Holley 4160. 4L60 transmission. ~ James
K10-Kansas is offline   Reply With Quote
Old 12-17-2025, 04:07 AM   #2
pjmoreland
pjmoreland's Avatar
Re: Engine temp sending unit backwards?
The resistance of the sending unit should go down as the engine temperature increases. The wire needs to be disconnected from the sender when measuring the sender resistance. If you leave the wire attached, then the resistance measurement will not be valid.
pjmoreland is online now   Reply With Quote
Old 12-17-2025, 09:51 AM   #3
HO455
HO455's Avatar
And your guage is upside too!
RIP Bob Parks.
Old 12-17-2025, 12:33 PM   #4
kwmech
Is the sender for a gauge or a light
Old 12-18-2025, 04:04 PM   #5
K10-Kansas
K10-Kansas's Avatar
Oh heck, I hope there aren't 2 different types of sending units. I'll check on mine and see which it is for, thanks.
Old 12-18-2025, 06:43 PM   #6
HO455
HO455's Avatar
There are two kinds of sensors. When testing the warning light senders they will show as open below the designated temperature of the sender and zero resistance above that temperature. They are simply a temperature controlled switch.
And as stated above remove the wire before checking with a meter.
One thing that can affect how the guage reads is how the needle is positioned on the shaft. Over the 50 plus years since new many times the needle has slipped on the shaft and that affects the needle position at normal running temperature.
RIP Bob Parks.
Old 12-18-2025, 10:13 PM   #7
MikeB
MikeB's Avatar
All I know is you can buy a three of them, and all would be a little different. And probably none exactly like your original. Even the originals from the factory may have varied and were paired with the appropriate shunt resistor for the gauge.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 12-17-2025, 06:19 PM   #8
MikeB
MikeB's Avatar
Good luck getting a gauge/sender combo to work. I've spent many hours on mine, and finally got it close after playing with several different shunt resistors across the top terminal and ground. The pointer doesn't start moving until ~150-160 degrees. Then it points close to straight up at around 200, and really starts moving fast after that. So it could be worse.
One of these days I'm gonna try an Autometer gauge/sender combo if I can make one fit the instrument cluster. This may be of some help, but all temp senders are not equal. https://67-72chevytrucks.com/vboard/...d.php?t=689065
Until then, here's a gauge I can depend on.
Mike
Old 12-17-2025, 06:38 PM   #9
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
I have a mechanical Autometer Phantom® mechanical water temp gauge. I hung that one under the dash because I didn't want to stand on my head to take the factory gauge out. The needle was going everywhere. Probably that resistor?
~Steven
Simi Valley, CA
Old 12-18-2025, 02:07 PM   #10
MikeB
MikeB's Avatar
Yeah, it's always fun to pull out the panel without removing the seat. If only I was 4" shorter and 30 lbs lighter!
Mike
Old 12-26-2025, 06:34 PM   #11
'68OrangeSunshine
'68OrangeSunshine's Avatar
Same here.
I re-engined my '71 GMC Jimmy K/1500 in 1999 with a Mr. Goodwrench 350 crate. The new electric Water Temp sender [from LMC -- I think] didn't work. I was told I needed to add some Resistors inline with the wire. That didn't work, so went with a mechanical AutoMeter gauge in an underdash kneescraper mount. Works great.
'68OrangeSunshine is online now   Reply With Quote
Old 12-26-2025, 07:29 PM   #12
Steeveedee
Steeveedee's Avatar
^ Yep, Bourdon tube is pretty reliable tech.
~Steven
Simi Valley, CA
Old 12-18-2025, 04:15 PM   #13
K10-Kansas
K10-Kansas's Avatar
Lol, I guess I could wire up the multimeter and and watch to make sure I don't go lower than 120 ohms.
Old 12-21-2025, 02:01 PM   #14
dmjlambert
dmjlambert's Avatar
Just an observation, in your first post the picture shows 128K ohms, not 128 ohms.
davepl gave us a chart of the exact readings from his temp sending in this post: https://67-72chevytrucks.com/vboard/...53#post7680753
This is about where the temperature gauge sits when fully warm
Old 12-21-2025, 10:53 PM   #15
K10-Kansas
K10-Kansas's Avatar
Thanks, I see he was getting about 70 ohms at 200 degrees. Graphs I've seen show 80 to 90 ohms at 200. My gauge doesn't start moving until I hit 120 ohms so it makes sense that my gauge just reads cold all the time. I wonder if I can change out the resistor plate on the back of my gauge.
Are you sure about the 128,000 ohms? My multimeter is showing 0.128 kiloohms which is 128 ohms. But, I'm new to all of this so I may be wrong.
Old 12-21-2025, 11:31 PM   #16
dmjlambert
dmjlambert's Avatar
My mistake, I didn’t see the decimal point.
Old 12-23-2025, 01:53 PM   #17
K10-Kansas
K10-Kansas's Avatar
I bought a potentiometer so I could test the LMC gauge. My numbers are coming up close to what Davepl showed in his GM chart so my gauge is good but my sending unit is not showing numbers anywhere near what Dave found when bench tested a sending unit with a multimeter.
My gauge is showing that my engine is 170 degrees but a temp gun shows the engine is 220 degrees. My sending unit is not a good match for the reproduction stock gauges and isn't in line with what GM shows on their charts.
I'll have to see if I can get a better sending unit or replace the resistor on the back of my gauge with a lower ohm resistor.
Old 12-25-2025, 09:17 AM   #18
1970cstblazer
1970cstblazer's Avatar
Exclamation Re: Engine temp sending unit backwards?
The common currently available (last 20 years) sending units are trash. Only somewhat accurate units are old NOS AC or Lectric Limited branded sending units.
Old 12-25-2025, 02:02 PM   #19
MikeB
MikeB's Avatar
That's close to how mine works now with an aftermarket sender. Mine's either AC Delco or whatever NAPA sold me. I can't remember the shunt resistor value.
My truck's operating temp is typically in the 190-200 range according to my engine compartment thermometer. So if the pointer is between 11:30 and 12:30, all is well. Still want to check out an AutoMeter gauge someday to see if I can make it fit. I've used the Sport Comp series electric gauges on two vehicles, and they work well.
Mike
Old 12-26-2025, 02:16 AM   #20
dmjlambert
dmjlambert's Avatar
This is the one I use, https://www.amazon.com/ACDelco-G1852...dp/B000C9SM22/, and I had it turned and re-threaded to 3/8 NPT by forum member A1971Blazer, details here in this thread, https://67-72chevytrucks.com/vboard/...d.php?t=703388
Old 12-26-2025, 04:16 AM   #21
Richard
If you have the new sending unit and reproduction gauge. I do not think the resistor on gauge is required. Maybe try that.
Richard
