Old 01-29-2026, 07:52 PM   #1
bradleyheathhays
bradleyheathhays's Avatar
Is early transfer case replacement a sign of an overworked engine?
I'm about to look at this '02 Sierra with 141k miles for potential purchase and the guy is having to wait on its transfer case to be replaced before showing it. I've seen a lot of trucks advertised, but not too many mentioning T case work being done at this early mileage.
Does T case replacement at 141k miles indicate the truck's been overworked with pulling heavy trailer loads? What signs of overuse should I look for on this upcoming inspection, keeping this T case replacement in mind?
https://imgur.com/a/9HFDHQv
'If the end of the world ever comes move to Kentucky, because everything there happens 20 years later.' ~ Mark Twain
bradleyheathhays is offline   Reply With Quote
Old 02-03-2026, 10:00 AM   #2
connorm
connorm's Avatar
Re: Is early transfer case replacement a sign of an overworked engine?
A lot of those trucks have pump rub issues. I believe it is the transfer case oil pump rubbing on the magnesium case, causing issues and eventually transfer case failure. If I remember right high RPM in 4wd makes this issue worse. Is this truck AWD? I think those also had more issues?
I don't know that the transfer case would scare me away from the truck as long as it is priced accordingly. At the very least I don't know that the transfer case replacement makes me think that the engine has had a hard life.
1970 C/2500 Ol' Green https://67-72chevytrucks.com/vboard/...d.php?t=668003
2016 GMC Sierra K1500
1953 Mercury 2 Door Sedan https://67-72chevytrucks.com/vboard/...17#post9381817
connorm is offline   Reply With Quote
Old 02-03-2026, 08:22 PM   #3
bradleyheathhays
Thanks for the responses guys. The ad says it's 4x4 so maybe that puts it into the higher failure category. Good to hear this is a common issue and not necessarily indicative of something more serious.
Old 02-03-2026, 08:06 PM   #4
hatzie
Moderator
hatzie's Avatar
It's possible the oil pump rubbed through the tailhousing case half.
https://www.merchant-automotive.com/...transfer-case/
There are two possible repairs.
Merchant Automotive makes a replacement for half of the pump housing.
https://www.merchant-automotive.com/...mp-Upgrade-Kit
Name:  Merchant pump kit.jpg
Size:  43.9 KBName:  Merchant pump kit2.jpg
Several outfits make a stamped steel plate to protect the alloy case half without disassembling the oil pump.
Name:  pump rub plate.jpg
Size:  58.3 KBName:  pump rub plate2.jpg
You'll need a case half if it's perforated.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
