Upper door molding help
I may be making this harder tan I need to, but I need ideas how to thread this screw into the nut. I can only access the flat nut with the door open and then the screw is inside the fender. Please don't say take door off.
![]() Join Date: Feb 2022
Re: Upper door molding help
The clip goes in behind the hinge arm and accessible but not easy with door in partially open position. Put the screw through the hole in door to get the feel of location. Carefully work the screw and screw clip in place than tighten. You work in a blind position so its all by feel.
I've seen people use some sticky stuff sort like tar to hold the back "nut" in place - probably any bodyshop can tell you what it is
Alternative: TAKE THE DOOR OFF
'72 C10 Cheyenne SWB North Carolina kept for 50 years, 75k original miles, Medium/Hawaiian Blue paint, 3 owners - one for 40 years & garaged kept. Original: sheetmetal, undercarriage, moldings, glass, immaculate unrestored bed. * * * New - rebuilt engine at 65k in 2015, one frame-on respray in 2010, front bumper, blue houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
Thin two-sided 3m tape.
"If it ain't broken, fix it 'till it is!" |
Super glue it on
| Bookmarks |
