Old 03-06-2026, 08:49 AM   #1
HeloCrewChief
HeloCrewChief's Avatar
Best option for inline 6 exhaust manifold
My 68 50th short bed needs an exhaust manifold. What is the best option out there? Skeptical of old used and the Chinese aftermarket ones. Seeing what way is the best option. I love my stock inline 6 and three on the tree set up as it’s different than all my other stuff and runs like a sewing machine. Not looking to do a header or anything like that.
1970 C10 to K20 conversion
1974 GMC Jimmy
1968 50th Anniversary Short Bed
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
HeloCrewChief is offline   Reply With Quote
Old 03-06-2026, 02:58 PM   #2
70STOVEBOLT
70STOVEBOLT's Avatar
Re: Best option for inline 6 exhaust manifold
I know you said you didn’t want used but your best bet is a used 292 manifold, it has a larger outlet.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 03-06-2026, 03:32 PM   #3
truckster
truckster's Avatar
I agree. Your options are limited.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is offline   Reply With Quote
Old 03-06-2026, 04:42 PM   #4
HeloCrewChief
Right on. Just worried I’ll get an original one and it cracks again. I’ve had more than a few cracked exhaust manifolds on different trucks over the years. Worse one was a 1991 V3500 with the TBI 454. Just curious if the reproduction ones are decent.
1974 GMC Jimmy
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
Old 03-08-2026, 10:21 AM   #5
PbFut
Is your timing off and over heating the manifold? Given poor selection of available replacement, is the crack in a repairable location?. Remove for prep, Drill each end of crack to contain it from running. V grind, reinstall, heat cycle a few times. Retorque, clean, then weld while warm.
PbFut is offline   Reply With Quote
Old 03-08-2026, 09:03 PM   #6
Jason Banks
Jason Banks's Avatar
I have used a China one with good results. I have several of the original style and they all have the shaft for the flapper flopping around so they would leak exhaust gas out around the shaft. Not to mention all the springs are shot.
If you get a China one, just make sure it is flat. I also took a die grinder to the one I used and cleaned up some particularly rough areas and extra material.
Jason Banks is offline   Reply With Quote
Old 03-08-2026, 09:08 PM   #7
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Yup, making sure it is flat is very important. I've assaulted exhaust manifolds with a straight bar and a mill file. It can be very time consuming, but if the manifold lays flat on the head, the stress and possible subsequent cracking are greatly reduced.
~Steven
Simi Valley, CA
Old 03-13-2026, 03:52 PM   #8
1964FarmFreshC10
Get the cast manifolds from 12bolt.
https://www.12bolt.com/store/p153/Ex...0-250-292.html
1964FarmFreshC10 is online now   Reply With Quote
Old 03-13-2026, 07:31 PM   #9
MikeB
MikeB's Avatar
That's pretty cool! Reminds me of Fenton split manifolds for the 235.
Rock Auto shows an imported manifold for the 250. Part number ATP 101140.
I ran a set of Chinese manifolds on my truck's 350 for around 12 years. They never leaked, and when I removed them to install headers there were no signs of cracks.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 03-14-2026, 07:33 AM   #10
Definitely the way to go. They make good sound too!
Old 03-15-2026, 10:00 PM   #11
'68OrangeSunshine
'68OrangeSunshine's Avatar
Clifford and Offenhauser both make [made?] aftermarket L6 intakes.
I have an Offy intake and Clifford headers. New in 1977. Still good. Still running.
Pace and Hedman make L6 headers, too.
If you're searching junkyards for the HD 292 GM exhaust, they are on the bigger trucks that were optioned L25 [292]. Best ''tell' is the THREE [not two] exhaust pipe mating studs.
'68OrangeSunshine is online now   Reply With Quote
Old 03-16-2026, 08:52 AM   #12
KQQL IT
At the body shop.
KQQL IT's Avatar
My brother's 56 with a 235-5 speed sounds awesome with a split manifold and a pair glass packs
