Old 03-12-2026, 10:33 PM   #1
JQ-72
JQ-72's Avatar
TH400 speedometer gears
I know there are online calculators where you can figure speedometer driven gears, but does anyone happen to know the teeth counts on a 3/4 ton with 3.54 and 4.10 gears?
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track
72 Cheyenne Super swb. 350/350 A/C, bucket seats
72 Cheyenne swb. Factory 402/400, tilt, posi, A/C
72 Cheyenne Super K-10. 350/4 spd., posi.
72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack
72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior
JQ-72 is online now   Reply With Quote
Old 03-14-2026, 11:46 AM   #2
PbFut
Re: TH400 speedometer gears
Tire size is needed. Also, there are 2 size and multi count drive gears that go on the output shaft. Without knowing all the variables, impossible to figure.
PbFut is offline   Reply With Quote
Old 03-14-2026, 01:29 PM   #3
howzzzit
howzzzit's Avatar
Your axle gear ratio determines how many times your driveshaft rotates for every full tire rotation. For example, a 3.73 gear ratio requires 3.73 driveshaft rotations to turn your tires once around. You should be able to find your gear ratio listed on the axle tag, however, if that has gone missing, you can simply count the number of teeth on each gear and divide the number of ring gear teeth by the number of pinion gear teeth.
[ Ring Gear Teeth / Pinion Gear Teeth ] = [ 41 / 11 ] = [ 3.73 ]
TCIŽ Auto https://share.google/R8IwduoEKFAxBm8Be
This site has drive, driven, and tire size calculators
howzzzit is offline   Reply With Quote
Old 03-14-2026, 03:50 PM   #4
JQ-72
JQ-72's Avatar
I know my axle ratios - one is a 3.54 Dana and the other is a 4.10 Chevrolet (Eaton, as some call it). I just bought a TH400 transmission local and the tag shows it to be out of a 1972 truck. It has a 41 tooth driven gear. Just wondering if it might fit right in with one of these gear ratios or if I need to swap the gear out
Old 03-14-2026, 09:35 PM   #5
Orange Crate
Orange Crate's Avatar
Where you gonna get the new gear?
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks, a 5 speed AND a front hitch!
Orange Crate is offline   Reply With Quote
