Old 03-25-2026, 06:54 AM   #1
cag
Active Member
454 dually header/exhaust question
My dually has headers that form into one tube similar to stock, this is a 3" in outlet, question is what are my options for down stream, a single 3" muffler? or do they make a kit where it splits right after the headers? currently has a single inlet and outlet flowmaster, better muffler options?
cag is offline   Reply With Quote
Old 03-25-2026, 08:50 AM   #2
THI
THI's Avatar
Re: 454 dually header/exhaust question
What year is your truck? Trying to figure out why a single exhaust vs dual exhaust.
From a different point of view, a 3" single exhaust flows about the same as a 2-1/4" dual exhaust if the intersection of the two pipes is not sharp. I have a 1979 C3500 Dually with headers and dual exhaust (it came from the factory with dual exhaust and no converter) and it is currently in need of a new system - plan on using a new set of Hedman Elite Heders along with a 2-1/2" dual system, they are available from Flowmaster and Pypes.
THI is offline   Reply With Quote
Old 03-25-2026, 09:10 AM   #3
cag
Active Member
its a 91 with throttle body injection and an o2 sensor in the pipe, I picked it up this way, the headers are stainless and not looking to replace, thinking changing the down stream setup
Old 03-25-2026, 12:33 PM   #4
kwmech
A 91 with throttle body injection will see no noticeable gains by using headers. Going back to the stock manifolds, a free flowing cat convertor an using a heated O2 sensor with the single 3'' pipe will be your best bet unless there were significant changes to the internals of the engine and a new programmed chip
Old 03-25-2026, 12:37 PM   #5
cag
Active Member
Originally Posted by kwmech View Post
a 91 with throttle body injection will see no noticeable gains by using headers. Going back to the stock manifolds, a free flowing cat convertor an using a heated o2 sensor with the single 3'' pipe will be your best bet unless there were significant changes to the internals of the engine and a new programmed chip
i got with the headers on, not changing them, heated o2? There is no cat...
Old 03-25-2026, 01:48 PM   #6
THI
THI's Avatar
If the O2 sensor is anywhere downstream you need a heated O2 sensor to operate properly (with or without a cat). If emission testing is not an issue (you mentioned no cat) I would go with one of the dual exhaust kits and get a collector that has the bung for the O2 sensor and wire in a heated O2 sensor.
The factory 454 TBI exhaust had two choke points, the factory "Y" pipe overlapped inside where the two pipes met, and the stock muffler choked down to 1-7/8" just inside of the 3" inlet. Because of excessive heat the converter was placed after the muffler. The exhaust manifolds themselves were not bad considering they had a 2-1/4" outlet. I mention this because if your system is using the original "Y" pipe cut to fit, you have the issue of the overlap at the connection of the two pipes.
Old 03-25-2026, 01:53 PM   #7
cag
Active Member
no testing here, wisconsin, and the o2 is in the header, this is like a tri y set up that the ps comes over and meets with the ds then has a 3" outlet, I guess a y pipe of sorts, thanks for the info all yall!
Old 03-31-2026, 04:39 PM   #8
SCOTI
SCOTI's Avatar
This is how mine is done. 1.75 x 3" full length headers into dual 3" head-pipes; though an 'H" pipe; into 3" In/Out mufflers; then reduced down to 2.5" dual tailpipes that discharge @ the rear bed corners.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old Yesterday, 06:18 AM   #9
cag
Active Member
nice, carbed big block?
Old Yesterday, 10:07 AM   #10
SCOTI
SCOTI's Avatar
TBI. Edelbrock TBI intake w/coolant loop deleted & TBI chip for the ECU. Does ok but the idle hunts (surging @ idle). I don't drive it enough to worry about it but it does fine @ speed.
I've debated swapping to a carb or spending more & switching to a Holley EFI set-up that's NOT TBI based. Most likely it will get a carb because big-blocks in CC duallys aren't exactly efficient so it seems ROI would be nonexistent.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old Yesterday, 02:39 PM   #11
cag
Active Member
where did you put to o2? how do you like that intake? did it make a diff?
