03-31-2002, 11:44 PM | #1 |
Brake Lights '68 Chevy c10
Signal Lights work in rear but no tail lights or stop lights. How can I rewire from cab to taillight assembly or to harness y under chassis? Also need wiring diagram
03-31-2002, 11:55 PM | #2 |
its all about the +6 inches
You won't be able to do it like that. I don't quite know how it is done, but the brake light signal splits to 2 wires inside your steering column. One wire for the left, and one for the right. If you were to just run a wire to your tail lights, it would not let the turn signals work.
only way to do a quick fix (instead of findng the actial problem) would be to add a set of trailer lights or something and wireing them up directly to the brake light switch. ------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
04-01-2002, 12:12 AM | #3 |
yellow is one side and light green is the other side, at column and at tail of truck and through firewall down by intake of engine near dizzy. probably is loose connection at taillamp assemblies or bad grounds back there, time to do housekeeping under tail of bed, resplice old splices, sand grounds where wires ground, WD40 on plugs, etc etc
04-01-2002, 10:23 PM | #4 |
hey showboat, I had a similiar problem with my 68 tail lights. My turn signals and brake lights wouldn;t work but tail lights would. Cmoe to find out that one of my light bulb connector for my turn signl was missing and that is what was causing my lights not to work. There is a circuit board on dash panel and if the connector is gone the circuit is broken. This may not be the problem, but might be worth looking into before rewiring.
------------------ blue 68 long wheel base 250 straight 6
Mike Cummings proud owner of a blue 68 lwb 250 straight 6, 3 on the floor. |
04-01-2002, 10:24 PM | #5 |
