Old 01-25-2004, 06:22 PM   #1
pissonNOS
senior member
pissonNOS's Avatar
Would these wheels fit?
I have a 69 would they fit?
http://www.billetspecialties.com/ite...pid=628&rdir=1
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 01-26-2004, 10:24 PM   #2
70 longbed
Probably not, the center hole is too small to fit the center guide on our drums.
Keith
70 CST longbed in progress. Hoping to get it back on the road soon.
70 longbed is offline   Reply With Quote
Old 01-27-2004, 01:23 AM   #3
bad69
Struggling Artist
have you converted over to disc in front? if so they will fit the front but you will have to have the rear axles machined down to fit the wheel center bore.
69 1/2 ton lwb lowrider
90 C-1500 2wd
08 2500 HD 4WD
94 Grand Cherokee
49 Cadillac sedan
bad69 is offline   Reply With Quote
Old 01-27-2004, 03:05 AM   #4
pissonNOS
senior member
pissonNOS's Avatar
**** that **** im gonna put them on anyways
69 GMC bagged
Old 01-27-2004, 10:04 AM   #5
Blue Beard
Blue Beard's Avatar
need to know bolt pattern, center hole size, offset, made for disc or drum brake.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-27-2004, 11:38 AM   #6
gr8scott51
gr8scott51's Avatar
Tells you right in the description that it fits 98 - 03 GM 6 lug. You'll have to work to make them fit PROPERLY. Scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 01-27-2004, 11:47 PM   #7
70 longbed
Bad69,
Do you replace the tie rod ends when you convert to front disc? The problem that I had with the newer style wheels was that once I changed the center bore size, thay hit the tie rod ends, and that was with standard size wheels, not the wider ones. I do not have the front disc conversions though.
Keith
Old 01-28-2004, 01:35 AM   #8
bad69
Struggling Artist
70 longbed; if you go with 17" or larger wheels it wont matter, they will clear them, but no the tie rods are the same and wont clear 16" or smaller wheels.
90 C-1500 2wd
08 2500 HD 4WD
94 Grand Cherokee
49 Cadillac sedan
Old 01-28-2004, 01:40 AM   #9
bad69
Struggling Artist
when I converted over I changed everything, drop spindles, tie rods,ball joints,and changed to 6 lug disc brakes,I did install 71-72 tie rods(sorry forgot).i think the tie rods are the same though.
Mitch
90 C-1500 2wd
08 2500 HD 4WD
94 Grand Cherokee
49 Cadillac sedan
Old 01-28-2004, 10:43 PM   #10
70 longbed
I see where the larger wheel size would eleviate the tie rod end problem, but I only had a standard size tire, P245-65 16 mounted??? and the tire itself rubbed when I turned the wheel to far in either direction.
Keith
