Old 01-25-2004, 09:59 PM   #1
djracer
djracer's Avatar
Went back to the track on saturday
I didn't improve much with the gears and posi! I went to the track sturday afternoon and made several passes! I was the only one running so we did't spray the track at all. I improved from a best of 9.128 1/8 mile to 9.103. I did have to pull the heads to install screw in studs and I'm sure I can do some more tweaking! I also improved my 60 ft time from a 2.08 to a 2.05!
For those not in on the earlier post! 71 short wide fleet with a zz4 clone with vortec heads, 1.6 roller rockers, 650 double pumper, turbo 350 with a small stall. Just changed from 3.07 single track to 3.73 posi.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-26-2004, 12:14 AM   #2
383 Stroker
383 Stroker's Avatar
What MPH did it run?
Video's of my Truck Racing
1967 C-10, 383ci Sbc, TH350, 3200 stall, 3.73 gear
383 Stroker is offline   Reply With Quote
Old 01-26-2004, 12:21 AM   #3
djracer
djracer's Avatar
1/8 was 76.49
1/4 was 93.13
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 01-26-2004, 01:10 AM   #4
bigjimzlll
bigjimzlll's Avatar
Hmmmm...were you spinning a lot more?
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 01-26-2004, 01:15 AM   #5
bad 71 chevy
bad 71 chevy's Avatar
how much hp are you pushing to the rear thanks
71 Chevy C/10 lwb 350
5 speed nv3500
3.73 rear end
2.5" Front Drop and 4" in the back
Edelbrock perfomer rpm manifold
Edelbrock 600 cfm carb
Headmen headers
bad 71 chevy is offline   Reply With Quote
Old 01-26-2004, 01:39 AM   #6
bigjimzlll
bigjimzlll's Avatar
about 270HP to the rear wheels
Anderson,CA
Old 01-26-2004, 01:44 AM   #7
djracer
djracer's Avatar
I actually had a better 60ft time. I thought it would pick up more. It may take just a little more tuning and another valve adjustment!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 01-26-2004, 01:57 AM   #8
bigjimzlll
bigjimzlll's Avatar
What cam are you running? and how small is the stall
Anderson,CA
Old 01-26-2004, 02:44 AM   #9
djracer
djracer's Avatar
"A new hydraulic roller camshaft (#10185071) bolsters mid-range torque and improves drivability without sacrificing peak horsepower. This dual-pattern profile has .474” intake lift and .510” exhaust lift. Intake duration is 208 degrees (at .050” tappet lift), and exhaust duration is 221 degrees." Quoted from Sallee Chevrolet website
These are the specs but I do have 1.6 ratio rockers instead of 1.5
The stall is about 2300-2500
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 01-26-2004, 10:26 AM   #10
kamkam1
went back to the track
djracer, what kind of tires were you running.
thanks
Kirk
Kirk Myers
68 chevy swb owned since 87, under the knife
71 skylark 9.20's @ 76mph 1/8 mile
kamkam1 is offline   Reply With Quote
Old 01-26-2004, 02:12 PM   #11
djracer
djracer's Avatar
M&H Cheater Slicks
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 01-26-2004, 03:25 PM   #12
PrimeredThunder
Back from the Dead
PrimeredThunder's Avatar
Any idea what kind of time that would be in the 1/4?
The only Carb that matters to me is the one under my hood!
Salem, Oregon
PrimeredThunder is offline   Reply With Quote
Old 01-26-2004, 03:29 PM   #13
djracer
djracer's Avatar
The best I've been in the quarter so far was14.30 and that was with the 3.07 gear I could only get a 14.39 saturday but who knows what the air quality differance was.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
