Old 01-30-2004, 01:42 AM   #1
Kenneth Brown
Post 307 crank?
I'm hunting a 307 crank. Anybody have one in good shape that are willing to part with?
Kenneth Brown is offline   Reply With Quote
Old 01-30-2004, 02:14 AM   #2
ZOOMY
crank
i have a good one. Crank is free. $50 to take it out & box it plus shipping. You can probably find one cheaper & closer....Zoomy
ZOOMY is offline   Reply With Quote
Old 01-30-2004, 03:14 AM   #3
1972C10
1972C10's Avatar
You building a large journal 327?
1972C10 is offline   Reply With Quote
Old 01-30-2004, 04:07 PM   #4
Kenneth Brown
No sir. I am gonna build a true hybrid. Its a 400 block with a 307/327 crank. The displacement comes out to 352 if memory is right. I also race dirt tracks. With this type of motor I should be able to gear it real high (or real low I guess you would say) and turn the rpms. I have run a 377 ( 350 crank in a 400) in the past and liked it alot. These type of motors are soft on low end torque. It makes it easier to NOT blow the tires coming off the corners.
Zoomy, I may be in touch soon, thanks for the offer.
Old 01-30-2004, 05:44 PM   #5
1972C10
1972C10's Avatar
Thats cool Some local engine builders talked about building some destroked motors like that for dirtrackers.
Old 01-30-2004, 05:46 PM   #6
ratrod67
ratrod67's Avatar
Where is Donie Tx? I should have one if you can pick it up. I'm in Ft Worth.
ratrod67 is offline   Reply With Quote
Old 01-31-2004, 12:49 AM   #7
soulman67
Randy churchill
soulman67's Avatar
I have one in south Texas. Just sitting in my storeroom. If you come and get it its free. I also have good pistons and conecting rods. I'll let you have to. All from a balanced and blueprinted 307.
1983 GMC K2500 6.2 diesel 4" lift on 35x12.50 tires
2008 GMC 2500HD 6.6 diesel 3" lift on 315 75 16X10
2003 Jeep Rubicon 4.5" short arm lift
1985 Jeep CJ7 30k in parts and still adding up
soulman67 is offline   Reply With Quote
Old 01-31-2004, 03:14 AM   #8
68 Suburban
68 Suburban's Avatar
Here you go.... Seems like a neat build. I was considering it at one point.
http://www.airflowresearch.com/artic...le03/A3-P1.htm
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 01-31-2004, 03:27 AM   #9
Kenneth Brown
Donie is about 70 miles west of Waco if you come down 35, or its right at 120 if you come down 45. Its near mile marker 190 on I-45
