Old 02-01-2004, 06:49 PM   #1
Couchsachraga
'74 "1 ton" 4wd
I'm looking at a '74 truck billed as a one ton, and I'm trying to figure out what axels are under it...rear end is dually, front is NOT the bud style wheels (e.g. completely different rims). So, is the front a dana 44 or? I seem to recall '78 was the first year a "real" 4wd one ton was produced, and before that though the rear was essentially a 1 ton, the front was the same as the 3/4.... I'm planning on using it for plowing and hauling sand / logs / stone (it is a dump).
Any thoughts would be appreciated!
Thank you,
Couchsachraga
Couchsachraga is offline   Reply With Quote
Old 02-01-2004, 10:51 PM   #2
Grim Reaper
No such animal factory.
The D44 is all that was available in these bodies in those years. The D60 front was not available till 76. What they are selling is a 3/4 ton. All one tons of that vintage were 2wd. You could also not get a 454 4wd till 88 in trucks and 93 in Subs and Crews.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 02-01-2004, 10:52 PM   #3
86k10
If the front axle only has 3 u-bolts and 2 bolts directly in the housing on the passenger side then it is a Dana 60, if not it's probably a 44 unless someone put a later corp 10 bolt in it, which in my opinion is better than the 44 anyway since it will have 3" axle tubes instead of 2-3/4".
98 Neon
97 Grand Prix GT
02 Grand Prix 40th Anniv.
86 GMC 5.0
77 Olds 98 6.6
REAL AMERICANS, DRIVE AMERICAN
86k10 is offline   Reply With Quote
Old 02-01-2004, 11:29 PM   #4
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
Ughh, that's not right.
My 84 light truck data book power team page shows the 7.4 Liter LE8 engine available in 1 ton 4wd regular and crew cab trucks.
EDIT- They started putting the 7.4 in K30 pickups in 1982 according to my factory brochures. /EDIT
The 454 was NOT available in 3/4 ton 4WD pickups or 4wd suburbans until after this series of trucks was gone.
Also, 1977 was the first year for the K30/K3500 (chevy/GMC) or the first year of true 1 ton 4wd pickups for GM at least in this body style.
Along with this, you couldn't get a 400 small block in a 2wd truck...
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is online now   Reply With Quote
Old 02-01-2004, 11:36 PM   #5
Couchsachraga
OK-Thanks for your replies!
One point of clarification-as it is a dually rear, would it be the same rear end as in the 2wd 1 tons, or a lighter duty unit? And what would it be...(I'm new to chevy's of this vintage...please forgive my ignorance!)
Thank you again!
Couchsachraga
Old 02-02-2004, 12:02 AM   #6
Grim Reaper
Your right...I'm flaking.
It's only the burbs you couldn't get a 4wd 454 till 93. The trucks it was available.
That's something I didn't know. I knew some folks with a 400 truck (at least if had a 400 badge on the grill) but I could have sworn it was a 2wd but it's been almost 20 years since I saw that truck.
Grim-Reaper
