Member #1049
FS: Van Tilt Steering column
For Sale..
1972 Van AT tilt steering column.. this is the easiest one to convert and install in our trucks... It has the correct levers.. even the neutral safety switch location is correct.. All that is needed to do is: Shorten your secondary shaft.. obtain the half moon wiring adapter from GM and put on your rubber seals.. install a neutral safety switch and put it in!! Sold as found in a local wrecking yard... will need cleaning up.. Will not ship.... Must be picked up locally...$175.00 (Have two) Also have one later model van AT tilt column that needs some help.. ($100) Email or call if interested.. (please do not "PM" me as I do not sign in very often) livrat@aol.com 206-406-2719 South Seattle Area.. |
