Would kinked fuel line cause idle problem?
I MAY have figured out my strange rough idle problem. I noticed that the line going from my PUMP to the CARB, is kinked...actually, I kinked it, haha. I tried to give it a 90º bend, by hand...never really thought that it'd hurt anything, until I read another post on here about kinked fuel line causing bad idle. So, I'm gonna just put a barb fitting on the pump, and run rubber hose up to the carb. Anyone done this?
#2 | |
I'm back with 2nd truck!
I agree with Riptide. get a braided line from pump to carb. I did this and looks much better and alot easier to manuever.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
#4 | |
Summit has a kit to run from your pump to the carb that you have. Just make sure to run a filter in it as well.
#6 | |
5 day ban, learn to behave.
a kinked fuel line wouldnt cause idle problems before it caused high load problems...
mike |
Tim, have you ever run out of gas? the truck dies because of lack of fuel. when you restrict the fuel flow, the same thing happens, but not enough to kill the truck.
I just looked at a truck that had the same issue.
The guy didn't even notice it. Was kinked around a bracket.......almost enough to completely cut off the duel supply....and it was a metal line. He couldn't figure out why it was hard to start and ran rough....
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
Fixed the kink..no change. STILL runs rich and like crap. I'm gonna swap back the primary jets (got a #66 in there now, gonna go back to stock #64) and HOPEFULLY that'll do the trick.
what seems to be the problem with your carb anyways? And how are you so sure that its the carb thats causing problems?
I saw you say something about rough idle.. primary jets have nothing to do with the idling of your truck.. What kind of carb? quadrajet I assume.. You check for leaky throttle shafts? leaky well plugs? How long since the carb's been gone thru? etc etc mike |
#12 | |
Under construction!
TIMSPEED and his never ending truck problems.....
2001 Silverado bagged on 22's. *Sold* Last edited by BaggedC10; 02-07-2004 at 02:44 AM. |
Just an idea but check your fuel float levels. With that new gasket you installed the floats may have been moved up or down to where they're not set right.
