Where are you guys mounting the spares
I went to put my new spare tire in the old carrier at the rear of the frame last night. Turns out that the wheel will not fit, it is a 15x8 wheel with a 23575r15 tire, it is too wide. I could cut those long bolts and add a piece in , or buy new, longer ones to make the carrier fit. OR... I could buy a cable type carrier off a newwer truck. Anyone done this, or have better ideas???
Thanks, Andy
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
spare tire
I had to do some real fabricating to get mine squeezed in just between the housings of my cell phone. I don't drive mine for my daily driver so I don't carry a spare tire.
Mine is in the basement. . . . . . . . .
Put it in the bed under a some sort of cover. Arizona sun will rot it in a week.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
Try spinnin 4 rear tars
I have a 235/75R15 spare hanging under mine. Used the tire carrier off of an early 90's Dodge pickup (that had 15" rims). I shortened the carrier ~4", drilled only 1 hole in the carrier and used existing holes in the frame.
I am now running 255/70R15 tires, still with the 235/75 spare, they are really close on being the same size so since I don't have a locker, I will get away with it. So, what I'm saying is, get a longer bolt and stick that tire back under there. I just hope your truk is stock height! My springs are sagging a little bit (I'm guessing ~2") I just hope I don't have a flat on the rear while I'm carrying a load, or it will be quite the fight to get that tire from under there, just isn't enough room. Keep that in mind... Good luck
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
![]() Join Date: Jul 2001
I have my spare mounted on the left side behind the back glass inside the bed. Can't put it under the bed since that is where the blazer fuel tank is. Not enough room for both the tire and the tank.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
hey 67drag,
what's the weight of that super smoker.... thanks for building it...these trucks do have a place at the strip.... |
I have my 16" 8 bolt 3/4 ton wheel under my bed, the thing weighs about 60 pounds. Sure beats having it in the bed.
![]() Join Date: May 2002
I'm using a rear Blazer gas tank so don't have room for a spare. Plan on keeping a 12V compressor and a bottle of Slime where the cab gas tank was.
Stepsides look like real trucks! Smitty ![]() |
Location: biwabik, minnesota, what is this white stuff out here
tire carrier ,,,,whats that, i didnt know these truck had them, well mine dont any way, not sure what happend to it either,lol
Beer Power!!!!!!!!!!
Did they come with one from the factory, mine is missing as well.
Rather be fishin' |
its all about the +6 inches
back when I had 5 wheels for her.
Formerly yellow72custom
Mine lays in the bed too, and tends to slam into my tailgate when i mash the throttle, and slam into my toolbox when i slam the brakes
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
#14 | |
weight
3275 lbs. Tom |
#15 |
mine has been sitting in the bed but now i have a flat bed i am now thinking of wher to keep it.
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
#16 |
in the bed. i want to find another place to mount it though
70 longbed 496/th400/Ford 9" |
#17 |
67dragtruck, if you don't mind me asking, how did you go about getting down to 3275?
--Scott |
#18 |
Self-proclaimed LED man
Im working on my spare tire setup right now. I just ordered a new "retainer" for my setup. I soaked it in muratic acid, and it turned the plastic into mush. It will be mounted in the original location, i got ahold of an original rim.
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once ![]() Norwood Survivor |
#19 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
On the rear bumper of my Blazer.
![]() And after the powder coating was applied ![]()
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 02-10-2004 at 03:32 AM. |
#20 |
Now the others dig........
under...see???
Under the bed, I had trouble with my spare being too wide, so I took some threaded rod and cut it longer than the older one, bent it up like I needed it to stay in the hole on the frame, ran a nut all the way up with a washer to hold it in place.bingo bango....luckily the rod was the same thread size as the original rod, and the thing that holds the spare up went on no probs.
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!! ![]() MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar ![]() TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
#21 |
I knew i forgot something. damn
#22 |
where spare??
Can't remember where or when but one of the neatest spare tire holders i've seen was when a guy took a spare "bucket---where the spare sits in a burb" and mounted it into the floor between the drivers side rear wheel tub and the front of the bed. Now he did have to cut some of the bed floor out and perhaps part of a bed floor support but----the spare tire sat in there low enough that the top was below the top of the bedside. REally neat setup. Not sure if that would work with a SWB but no problem with a LWB. Of course you can always get a fleetside spare tire mounting bracket and bolt the spare to the bracket but then it's very visable so you would want to cable or chain it in as well.
#23 |
WHYBYNU when old will do?
I don't have a spare
-72 Chevy C10 Stepside -2002 Chevy Silverado 2500HD 4x4 -1984 Jeep CJ7 -1995 Polaris XCR600 Custom -2003 Honda 300ex |
#24 |
New KISS Band
mines in the trash it wouldnt have done me any good its was flat
67 chevy 350 HP 4bolt main turbo 350 3.73 gears |
#25 |
F.A.S.T. president
![]() Join Date: Sep 2003
I dont carry a spare, I have a plug Kit and an air compressor. If its shreaded then I AAA it.
I have a plug kit in all me vehicles I find it easier and faster to just put a plug in it an air it up. I only use the spare on the other vehicles if a plug wont fix the problem. |
