AT Linkage question???
How much are the Automatic Linkage set ups going for from our Board member sellers??? Are they hard to come by? JunkyardJohn has a set-up on ebay and it is approaching $50.00 and maybe more. What should a guy expect to pay. I ask because I have 3 on the tree and want it to be column shift AT and want to be the informed consumer.
Alex 1971 Lil' Red 350 SBC 700R4 |
I purchased the lokar linkage for 29 bucks and works great and cleaned up the cobled look that GM has.
I was in the same shoes as you, after searching around for about 3 weeks here on the board and at junkyards. It was cheaper to order an aftermarket set from Kugel Components. If you wanted the complete factory setup, trying to get new bushings and spring and shift lever, those where the main parts I couldnt find. There site is http://www.kugelkomponents.com/ and all in all I paid about $60.00 for it.
1971 LWB Chevy C-10 350/350 3:42 eaton ![]() |
Thanks guys!
I picked up crossmember, Stearing Column, all linkage at junkyard for $25 had to pull it all myself too...
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I ran the lokar linkage on my last chevy and it worked really killer and should do it on my blazer but the stock linkage is still in great shape..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
I'm going Lokar!
