02-10-2004, 11:04 PM | #1 |
Manual to Auto linkages, etc
I am taking out my 4-speed and putting in a 700r4.
I need to remove my pedal set up with one from an auto, and get an auto steering column. Are the 700r4's the same as the TH-350's as far as shifting goes? Can I use the TH-350 linkages and steering column? Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
02-10-2004, 11:07 PM | #2 |
I don't know about the 700r4 linkage but the pedal from my clutch is still hanging there since I did my manual to th350 swap a year or two ago. I'm pretty sure the brake and gas are the same on both manual and auto.(I have a 700r4 in the shed waiting for a rebuild)
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
02-10-2004, 11:34 PM | #3 | |
IT'S JUST A MATTER OF REMOVING THE PEDAL RETURN SPRING,REMOVING A "C" CLIP & SLIDING THE HORIZONTAL SHAFT & CLUTCH PEDAL OUT. TAKES ABOUT 2 MINUTES. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
02-11-2004, 09:19 AM | #4 | |
However the look on peoples faces when they push the clutch is priceless. (Lots of people hop in at the boat ramp at tournaments and pull me out while I'm solo). Thanks for the tip. Now I'll have to look.
