02-11-2004, 09:27 PM | #1 |
Junior Member
Swap 70 PU Cab to a 1990 Sub 4x4
Hello
I have access to a 1970 PU Cab and Frontend. There is no frame or bed, however I have gone through all the points that habor rust in this vintage truck and there is none. The farmer has it stored in a hay barn, several in fact. I have a 1990 4x4 Suburban, solid front axle with a wheelbase of 127, that is a great daily driver that I am considering making into a donor chassis for the 1970 PU. Is this possible? What are the biggest issues that I will face? Has anyone done this? Thanks for the time. Last edited by WestCoaster; 02-12-2004 at 02:35 AM. |
02-12-2004, 01:23 AM | #2 |
the body mounts may not be right on... also i dont believe the wheel bases will match up either. no big deal if you are considering a custom flat bed. i know i WILL be corrected if i was wrong.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
02-12-2004, 10:46 PM | #3 |
If you can weld, the world is yours!!!
