02-13-2004, 04:28 AM | #1 |
Killin' Time
hotrod header problems
hey guys, my friends hotrod seems to be rejecting all the headers he can throw at it
the hotrod happens to be a F*rd (sorry) but it has a small block chev in it!! So, its a 53 F100 with a roller 355/th350. It has a rear steer nova clip with power steering (not too sure on the details of that). Block hugger headers hit the steering box with the primarys (slightly) and the frame both sides, and the collectors come out right on top of the radius arm that connects the tie rods It is a pretty custom job, so I'd just appreciate it if someone could maybe take a guess as to what kind of headers might possibly fit here it is
NEED CORVETTE 1972 GMC C20 350, SM465, HEI Dynomax headers and 2.5" duals Last edited by dregs454; 02-13-2004 at 04:31 AM. |
02-13-2004, 05:57 AM | #2 |
What are some of the brands tried? And would it be safe to assume they are short style headers? I would imagine that the only type that may fit are going to be shorties or stock manifolds. There is just too much that has been modified. I would build a set. It is not that difficult. Even if you have to tack a kit together and get someone else to TIG them, I think it would be worth it in the long run. I'm just afraid that if you find a set to clear the gearbox and frame there will be other issues like starter or oil filter interference. Hopefully I'm wrong and someone else can recommend something. If you want to look into building a set start here They are great. Good luck and tell your buddy that's a nice looking truck. Needs a 429 and Mustang II set up though :p
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
02-13-2004, 09:06 AM | #3 |
its all about the +6 inches
What part numbers or vehicle aplications did he try? I would say that a set of Nova headers whould fit right up with the only possable interference would be the steering shaft and maybe the heater box.
02-13-2004, 10:20 AM | #4 |
ran out of money
just an idea, how about LT-1 headers for like an impala or camaro....... they go up and back before they go down.
good luck Rat
Modify everything, leave nothing alone!~ |
