Old 02-14-2004, 11:47 PM   #1
Stepsides 4Ever
Stepsides Are Bedder
Stepsides 4Ever's Avatar
'73-'87 Crossmember In A '70?
Ok, I have a fair understanding of what fits what as far as converting my 1970 SWB Stepside to later model disc brakes, but will the crossmember from the '73 to '87 bolt up as easily as the '71-'72s do (slight modification to bolt holes), or is this a whole different animal? Sure seems like it would be easier to remove at the bone yard and disassemble it at home with my air tools, but I don't want to pay for the crossmember if I can't use it.
Stepsides 4Ever is offline   Reply With Quote
Old 02-14-2004, 11:54 PM   #2
krue
Designated A-hole!
krue's Avatar
You just have to slot two holes in the frame.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 02-15-2004, 12:04 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I thought the frame was wider in that area or something?
Old 02-15-2004, 12:55 AM   #4
kaycee
kaycee's Avatar
Talking Bolts
right in except for the 2 bolts allready mentioned.The brake lines in front will need a little reworked.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 02-15-2004, 01:09 AM   #5
Stepsides 4Ever
Too cool!
Somewhat off-topic, but what about the power brake booster/master cylinder/proportional valve/pushrod/mounting bracket from the same years ('73-'87)? Will those pieces fit as well?
I've read that the power steering box (up to model year '81) is interchangeable...is there an easy way to identify which box is the variable ratio variety?
Someone should write up some sort of interchange guide if it hasn't been done already!
Old 02-15-2004, 11:37 AM   #6
Longhorn Man
Hot damn, I have been thinkng they didn't work.
Old 02-16-2004, 02:19 PM   #7
PR454SS
PR454SS's Avatar
Originally posted by Stepsides 4Ever
Too cool!
I beleive the only difference in the power steering box is that they went to Metric fittings with o ring seals, I got some adapters with my variable ratio box from Corvette Steering.
PR Too many projects, not enough time!
72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold!
69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam.
78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's
77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs
PR454SS is offline   Reply With Quote
