02-18-2004, 01:44 AM | #1 |
Happy to be here
KRZ Customs ?
Anyone have any pro's or con's on this shop? I'm not looking for rumors or . If you have facts about their quality, let me know...
02-18-2004, 04:01 AM | #2 |
Isn't KRZ located in Fresno or something? I'd be more than happy to take a ride and look at their shop if need be...
02-18-2004, 11:31 AM | #3 |
Happy to be here
Yeah they are in Fresno. I am "considering" one of their body dropless frames. Just trying to get some input on their work. Everything I have read on FSC.com and Sportruck.com seems to be very positive...www.krzcustoms.com
02-18-2004, 02:44 PM | #4 |
Under construction!
KRZ Customs is an excellent shop. I believe they were one of the first shops in NorCal too. I've heard nothing but great comments about their components and service.
2001 Silverado bagged on 22's. *Sold* |
02-18-2004, 08:13 PM | #5 |
Project92 SWB stepside
I was talking to another shop owner in Cali and he also said they do great work.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
02-18-2004, 11:14 PM | #6 |
I seen one of their bodydropless frame's at a local carshow a while back. Looked like top quality. You're thinking about getting it for the Blazer Ken?
02-19-2004, 01:20 AM | #7 |
Happy to be here
It's one of the many thoughts right now. I am working with Roger at Stoked Out Specialties where the Blazer is now. We know we want the front lower than the stock suspension will allow without major mods. We have been looking at all the IFS on the market, and weighing the pro's and con's.
By the time we mod the stock frame like we want, it may be more cost effective to have a frame built. We considered that too, but most frame builders want a fortune, and they aren't "designed" for bags. They "convert" them, but they aren't designed for them. The KRZ set up is "designed' for bags, and will lay frame with 22's or 24's. I don't plan to run 24's, but 22's aren't out of the question... |
02-19-2004, 02:27 AM | #8 |
its just $$$$$
why did you have to post this, now you have gotten me to thinkin. Have you talked to them about makin one for a blazer? Maybe we could get a deal if we bought two. hahaha
02-19-2004, 06:05 AM | #9 | |
02-19-2004, 07:16 AM | #10 | |
02-19-2004, 10:49 AM | #11 | |
Happy to be here
That is all correct. I'm not after "laying" frame so I can drag stuff off and make cool sparks. I just want it to hover above the ground with a slight rake while rolling through the parking lot.... |
02-19-2004, 10:54 AM | #12 | |
Happy to be here
I also like the fact that is uses 88-98 GM truck balljoints. That means no Mustang II arms or spindles. They do use a modded M II rack for steering, but the frame isn't notched. It has a kick up so it clears the rack without a notch. |
02-19-2004, 11:59 AM | #13 | |
02-20-2004, 01:15 AM | #14 |
Happy to be here
Scoti,
Yep, you got it. They set it up for 88-98 ball joints and everything is 88-98 too. What that means is it will have "truck" suspension under it rather than Mustang II parts.... |
02-20-2004, 09:37 AM | #15 |
FUEL CELL GURU
Go to...
Yahoo and type KRZ Customs in the search box. Look through the first few pages. There were a couple to three results from message boards where some were really slamming their work. I think their chassis look great. Wouldn't mind having five or six.
02-20-2004, 10:25 AM | #16 |
Happy to be here
Mark I'll try that. I did a search on FSC.com and Sportruck.com already. Everything that came up was very positive. I haven't read anything bad so far. Looking at the pics on their site tells a lot too. It appears they turn out some top quality work.
The question is is it worth it compared to an aftermarket IFS and slicking out the stock frame... |
02-26-2004, 01:52 AM | #17 |
hey N2TRUX did you hear a price yet? just curious it might change your mind real quick?
'82 chev swb 4dr 2wd project '72 2wd blazer LT1/4L60E "SURFSIN" bagged 20's '71 2wd blazer '95 chev 2wd Xcab swb |
02-26-2004, 10:40 AM | #18 |
Happy to be here
Yeah, they told me 4000.00. That gets you the basic frame and A-arms. You provide everything else, including motor mounts, trans crossmember, body mounts, rear suspension mounts, tanks mounts, spindles, etc.... It gets pretty expensive no matter how you look at it.
We finally decided to go with modding the stock frame, and put a Scotts Hotrods IFS on... |
02-26-2004, 11:06 AM | #19 | |
Trucker.
02-26-2004, 12:00 PM | #20 |
Happy to be here
Izzy, I spent a few hours at Stoked Out this weekend discussing all our options. Roger was very patient going over all the possibilities. We talked about building a frame, buying a frame and modding the stock frame. After considering all the options, and what we wanted the end result to be, we decided to go with replacing the stock front suspension with a Scotts IFS.
We will have to replace the front frame rails with wider pieces to clear the a/c on the LS1. This is what they did on the 62 T-bird they are building.... |
02-26-2004, 03:45 PM | #21 |
Trucker.
Looks great. I was eye balling all those pics for a while.
We're having a meet for FSC in Rowlett next Sat the 6th maybe I'll swing by Stoked Out if they're open. |
02-27-2004, 12:31 PM | #22 |
Happy to be here
Give Roger a call. He's a super nice guy, and would probably love to show you the shop. You can see my tired @ss Blazer, and my 77 which is now in pieces again...
02-27-2004, 03:23 PM | #23 | |
Under construction!
Uh-oh. What are you up to now, Ken?
02-27-2004, 04:02 PM | #24 |
I don't think Roger has time to show anyone the shop. I hate to admit it.... but I work alot of hours & he can make me look like a part-timer.
Between his personal vehicles, customers vehicles, shop projects, chasing down parts (like a 1-off steering rack for a 2 seater Mercedes w/an LS1), homeowner responsibilities (and squeezing in time for the wife & kid), friends, family, church......he never lets up. I wish I was 1/2 as motivated.
02-27-2004, 05:31 PM | #25 | |
Trucker.
