![]() Join Date: Nov 2001
Tach dash question...?
I scored...I am being given a tach dash out of a '71 c-60 truck,Is there anything besides the dash itself that I should grab out the the truck?going to pull it Saturday.Is there a tach wiring harness? or some other little pieces that these big c-60 have, that could be used? I have one chance at this truck...
Bryan in South Dakota
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
Get the wiring harness for the tach. Not much but you will need one. See if it has a vac gauge and get that stuff. Oil pressure line.
Basically, if it attaches to anything in the dash cluster, take it.
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
Grab all the wire harnesses from distributor to Tach. Unless you just want to add the wire. I have the crimp connectors if you need them for mods.
Larry 68 C20 327 daily driver 63 C20 292 Camper truck 65 C10 ? Custom Cab AC,PB,PS,$flasher |
