Dreams are free
front 5 lug disc convertion questions
I've red all the ways to do it a couple of years ago,
and now I'm ready to begin, I can use all the advice I can get. I've got a '68 , that I have most of the '72 parts to go under it. but if my memory will serve me correctly, I think you used all '72 parts, exept for the inner tierod end, if i keep the '68 drag link? can someone please enlighten me on the correct way one more time, Thanks John
'68 swb fleetside originally w.i.p '68 member since 1-01 w.i.p = ( work in progress ) |
Dreams are free
this is waht I have.
in the way of new parts 72 spindles ( not new) turned rotors new brake calipers w/brake pads upper& lower ball joints inner& outer tie rod ends brake hoses/ with banjo bolts upper and lower control arm bushing kits brake booster w/ master cyl, shocks. I've been buying a little at a time, chassis/steering parts are expensive, what else will I need ?
I did it on my 69 you will need the upper and lower ball joints for a 72. You will have to change the inner outer tie rod ends and the sleeve. These are Auto Zone part Numbers 1 inner ES403L, 1 inner ES406L 2 outer ES415R, 2 ES20045 adjusters. Cant really remember which went were but they will only fit one way. I think the ES406 has to be the inner on the driver’s side. I keep my draglink that is why You need the ES406L the hole on the 69 draglink was smaller then the one on the 72.
Dreams are free
TTT please help
6 lug to 5
can't tell you what to do but I started to do the same today to my 70.Started with the rear end today so will stay in touch with you on info.Good luck Butch
Dreams are free
I've done a search, and must have missed the answers I'm looking for, if I use a 68 drag link, then I use the 68 inner tierod ends, and 72 outer, and they both will fit in the adjuster sleave ?
is this correct.
I used a 72 drag link when i switched my 69, i don't know if the 2 different tie-rods will fit the adjuster sleave or not, you could always try it at the parts store
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
