04-02-2002, 10:45 AM | #1 |
Shortbox wanna-be.
Can the oil pan be removed on a 402?
Is there enough room to get the oil pan off the engine on a BB402?
Or does it need to be jacked up or anything? I would like to fix the oil pan/rear seal leak and maybe check a couple of bearings while I'm in there. Reid ------------------ Sylvan Lake, Alberta, Canada 1970 Chevy C20 Custom Camper #s matching 402BB Turbo 400 trans. Air conditioning, power steering, manual brakes. 73,600 Original Miles!! (Add on 2000 more from raod trip!)
1970 Chevy C20 Custom Camper 402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton) '71 Camaro SS 402/T400 resto '97 Z28 (11.41@127MPH) |
04-02-2002, 12:33 PM | #2 |
Yes it can be done,just a messy sucky job,my opinion be easier/faster to pull motor and put on a stand if you have the time,space,tools.only takes a couple hours.
04-02-2002, 12:34 PM | #3 |
but i hate lying on my back in the driveway for long periods of time,seems i do better work when i cant stand over it and spill stuff in it.
04-02-2002, 01:49 PM | #4 |
Shortbox wanna-be.
Thanks for the info. I will probobly just try and do it in place. I am used to working on a '97 Camaro, so this will be a piece of cake. I just wasn't sure if there was enough room to slide it out of there.
04-02-2002, 01:59 PM | #5 |
Micah,
Is that you responding? Great to see you back on the board. Larry |
04-02-2002, 02:44 PM | #6 |
Weapons Of Construction
Had to do it on mine to reconnect the oil sump the previous moron didn't install correctly. I pulled the bolt out of the driver's side motor mount and used a 2x4 on end on top of the floor jack to lift the engine enough to get the pan past the flex plate. I used the power steering bracket (I think) on the front of the engine to push up on. The pan won't come out of there unless you lift the engine a little.
1971 GMC 2500, 402/TH400 4.10 Daily Driver Lafayette, CO |
