Old 02-25-2004, 11:31 AM   #1
arodvw
Burb not running right......HELP!!!
I have an 85 Burb. Had a Brand new crate motor and Edelbrock intake and carb installed a couple of weeks ago.
Heres the problem......after driving around for a while, when I get to a stop light it begins to run rough then dies...What can be the problem? Timing? Carb adjustment?
Thanks in advance.
arodvw is offline   Reply With Quote
Old 02-25-2004, 02:07 PM   #2
bpmcgee
bpmcgee's Avatar
Could be choke not turning off. Could also be idle mixture, have you adjusted it?
Brian
bpmcgee is offline   Reply With Quote
Old 02-25-2004, 02:30 PM   #3
BigRed
Does it only happen when it's hot? If so, you may think about the fuel pump. Mine started acting funny with me when it would get hot before it went out.
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 03-01-2004, 01:10 AM   #4
arodvw
bpmcgee, it was the choke and the timing. Its running good so far. thanks for your help.
