Old 02-25-2004, 07:17 PM   #1
'70_402
'70_402's Avatar
What is the best upgrade?
What do ya'll think is the best upgrade for the money?
Engine?
Brakes?
Suspension?
'70_402 is offline   Reply With Quote
Old 02-25-2004, 07:23 PM   #2
gr8scott51
gr8scott51's Avatar
Didn't we have one like this before? something like top 5 alterations?
Lots of folks voted for the power disc brakes. Power steering is sweet if you are using arm-strong steering now.
scott
oh yeah, sway bar, too
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 02-25-2004, 07:41 PM   #3
krue
Designated A-hole!
krue's Avatar
power brakes is a good bang for the buck and also fairly easy to do.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 02-25-2004, 10:52 PM   #4
speesh
speesh's Avatar
brakes, because crashing sucks!
been there, done that....
57 suburban(sitting in the driveway), 2 69 C20 longbeds (sitting in the field ) and a 2003 8.1 Suburban
Endeavor to persevere.
"All of a sudden, I'm the old timer!" Some old timer on American Pickers.
speesh is offline   Reply With Quote
Old 02-26-2004, 12:11 AM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I did the suspension, first. It needed disc brakes, and it needed to be lowered. The control arm shafts and bushings were worn, as were the ball joints. The engine ran good, and the tranny was in good shape. This was in the fall of '01. I haven't done anything else to any part of it, short of replacing the battery and the heater blower motor. It still starts, rides, drives and stops real good. I'd like to put a new engine in it....and a 700R4. But, it still runs and drives and probably will for a long time....with the same engine/tranny combo.
In my opinion, if you can't drive it and enjoy the drive, nothing else that you do will have any value, including paint and interior, as well as the engine/driveline. If it feels good on your butt, you won't mind getting off of your butt to do something that it needs. If you don't like driving it, you won't want to spend money on it and you should just go ahead and sell it.
Member Nr. 2770
Old 02-26-2004, 01:20 AM   #6
botboy
I consider myself fortunate that my truck came equipped (factory) with power steering, power brakes, and tilt column.
The first things I've done to my truck (not necessarily in this order) mostly because they're cheaper:
Sunpro Tachometer - I want to know if my automatic isn't shifting when it should
Electric fan - few less parasitic HP, slightly better mileage
New rear coils - one was missing when I got truck, helps with ride too.
CD Deck - Makes for better driving experience
Cab corners - When its this cold out and you don't have cab corners, it definitely improves driving experience! As well as several other rusty/bent body panel replacements.
100 Amp 1-wire alternator - cleans up engine bay (less wires no regulator) less flicker, more power for stereo above, brighter headlights.
Things I'm planning on doing:
NV4500 (Probably just a SM465 for now). Slightly better mileage, less likelihood of failure (compared to an auto), better burnouts. And I like bangin thru the gears.
Posi rear end - for better hookups and a better chance of getting out of my icy driveway
Headlight relays - brighter lights, less flicker, longer lasting dimmer switches
IRS - (way down the road) for better cornering and daily non-hauling driving
botboy is offline   Reply With Quote
Old 02-26-2004, 01:21 AM   #7
kaycee
kaycee's Avatar
Talking Engine
HEI
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 02-26-2004, 02:14 AM   #8
bigvinnie
bigvinnie's Avatar
ditto on HEI.... set it and forget it...
disc brakes would also be a good return on your investment...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 02-26-2004, 02:36 AM   #9
67_SS396
The best upgrade? Big Block! Then I'd consider upgrading the brakes.
However, with my daily driver, the best upgrade so far was a front sway bar. It still has four wheel power drums which is plenty for stopping. It just takes a little longer than the rest of the soda cans on the road.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 02-26-2004, 04:26 AM   #10
Sweet72
Sweet72's Avatar
I'm with gr8scott51, krue and speesh on this one. Power disc brakes if ya don't have 'em. Goin' real fast is cool, but not being able to stop before you hit the car ahead of you really sucks!
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
