Old 02-25-2004, 10:17 PM   #1
larryboz
Have some questions???????
I have a 1969 that I am starting to redo so here are the questions I have I am changing from 6 lug to five lug.
1. I am going to lower it 2.5 or 3.5 front and 3 or 4 in the back would you guys go with Early Classic or CPP?
2. Which bolt pattern Early classic says 5 on 5 and CPP says 5 on 4 3/4. Which would you guys go with?
3. I want to convert power brakes and steering which kit would you guys go with?
Any advice would greatly be appreciated
Larry
1986 3/4 Chevy Truck 454
2005 Z71 Tahoe
2002 Pontiac Trans Am WS6
larryboz is offline   Reply With Quote
Old 02-26-2004, 12:11 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I use only Early Classic stuff.
The bolt pattern, definitely go with the 5 on 5. That's a truck pattern and you'll be able to get a five lug rear end to match it as well as running normal Chevy pickup wheels. The little 4 3/4 pattern is for car wheels.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 02-26-2004, 12:28 PM   #3
ncbiggj
5x 4 3/4 is a truck pattern also.. it is the pattern for the toyota trucks 2wd. That is the pattern that I went to on my mazda to have a better selection of wheels for it.. but I would go with the 5 on 5 for the chevy, he is correct that is the normal pattern and have good wheel selection for the 69.. That is what I am going to..
ncbiggj is offline   Reply With Quote
Old 02-27-2004, 05:51 PM   #4
72LOWBOY
I agree with Tx Firefighter on using Early Classic suspension components. Maybe a little pricey. But you get what you pay for.
72 Chevy LWB leaf spring rear,SBC 385 Fast Burn,Art Carr built 700r4,3.73 Eaton posi,one piece windows,lowered 4/5.5, 60/40 seat, shaved turn signals,shaved reverse lights,shaved stake pockets, stainless steel 21gall in rear, c-notched, vintage air,ps,pb,currently doing body work.
68 Camaro conv.327,turbo 350,pb,disc brakes,built it for the wife
38 Chevy Coupe on the back burner
LIFE IS GOOD! SMILE
72LOWBOY is offline   Reply With Quote
