![]() Join Date: Nov 2002
Ideas on my leak?
Truck has been sitting for about a month or so. I started it up , let it idle for a couple of minutes moving another car off the driveway, then drove about a mile to the gas station. Found fresh engine coolant in the "dimple" in the left front of my intake manifold, and a small line of fluid all down the left engine/intake manifold/valve cover area. No visible leak. I dried it all off and ran it for another 5 - 7 miles or so and checked it again... Still no more leak.
The engine is a '79 350 so it has the thermostat cover on top of the engine in this same area. Any chance that after sitting in the garage for a month that the gasket around the thermostat dried out and allowed the leak until it swelled up again? No fluid in the oil so i don't think its a cracked block, but is is weird. Any ideas?
"Truck" '67 small window '79 350 .030 over, LT1 "clone" |
My first thought would be the t-stat housing but it is possible to get a leak from the manifold bolts. If you can get one, put a pressure tester on the radiator and pump it up to 10 PSI and let it set. Your leak should show up.
Jim |
English Chevy Owner
T-stat housing, mine does exactly the same, I've got an aftermarket cover with the O ring seal and nogasket, but the intake manifold is a little corroded underneath it and it just won't seal. I've tried everything, gasket with sealnt, gasket without, O ring type, just sealant. I'm getting a nerw intake manifold soon so that should sort the problem, but I bet that's where your water is coming from.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
Thanks Y'all
I appreciate the assistance. Drove it for 30 -45 minutes... No leak.
Don't you just hate to troubleshoot intermittent faults? Thanks again.
![]() Join Date: Apr 2000
Check the bolts on the t-stat housing and the intake to make shure they are tight. Check the hose clamp too.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
