3/4 ton gear ratio?
im buying a 79 3/4 ton for teh axles to put under mine when i get it all back toghther.
the truck came wiht a 292 6cylinder 3speed and a 205 t case..the guy im buying it from says he thinks they are 3.42 or 3.56 gears but he cant remember, my brother in law says with a 6 cylinder 4x4 3/4 ton they would have to be 4.56 or 4.10.. any one know off hand wich they might be either way its better than the 3.08 crap i have now. thanks stan
79 chevy k20 350/350/205/D44/14bFF 4.56 gears rock ![]() LWB pimer black 01 S-10 ZR2 extended cab 4.3/4L60E/233 3.73 gear 31" DICK CEPEK CRUSHERS |
the front axle is an 8 lug gm 10 bolt the rear is a 14 bolt full floater if that helps
stan
Irecently picked up 3/4 ton axles for my truck a nd my 14blt. ff had 4.10 but i dont know what truck they came out of I just picked from a pile. I'm not sure about yours. I would say 4.10 because I think that most of them came with that gear. you can divide the # of ring gear teeth by the pinoin teeth or vice versa and figure it out that way. By the way does it have the removable pinoin? That would make it easy to count the pinion gears.
The Blazer King
My FF rear has 3:73. It sucks.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
Registered truck nut
I'd bet they're 4.11's but could be 4.56
MOUNT VERNON, WASH. STATE Need a part? Just PM me |
4.10s are most common, but 4.56s arent out of the question. 3.73s are extremely rare.
#7 | |
Collector of rusty Items
What is common? I suppose that 3.42 or 3.56 axles would be more widely acceptable in the midwest and such where you don't have as many hills to climb.
Scrub Sisters, Oregon - Home of the Sisters Rodeo. 70 GMC 1,000,000 + miles 72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends. |
