02-29-2004, 02:54 PM | #1 |
New issues - Help !!
Edit: ---> Solved-----> Swervin Ervin--> is the winner !!!!
Thanks Swervin !! Changed out the ditributor, and shazammmmm.... Fires up like a race car and kicks ass.. ------------------------------------------------------------------------------ Got my engine broke in , but it's got issues Specs: Edelbrock 1406 600 CFM -Carb Summit HEI High performance Distributor Power+Plus Polished Manifold Competition Cams 327 - 350 HP Cam Duration .280-.280 / Lift .480 /.480 Lobe separation: 112 (I will double check the cam specs, but should be right.) I am putting all I can think of or done; 1. Timing is jumping between 8-10 degrees 2. Vacuum is weak 3. Hard to start (valves are set right-) --> will back fire through carb (catches fire sometimes) --> have to advance dist higher to start 4. At idle guessing 800-900 rpm, when I put in gear - it dies. Idle is good and runs on it's own otherwise. Last edited by Nvbowtie; 02-29-2004 at 07:12 PM. |
02-29-2004, 03:00 PM | #2 |
NV,
I don't know anything about your engine, so forgive me if I'm bringing up things you've already checked. It really sounds, as if you have timing issues or a vacuum leak. Have you checked that TDC on the balancer really corresponds to TDC on #1? Brian |
02-29-2004, 03:14 PM | #3 |
I'm back with 2nd truck!
Sounds like my problem I had when I got mine started the first time as well. I was a tooth off on the dist. Check to make sure that you are dead on and retry. Also check for vacuum leaks.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
02-29-2004, 03:21 PM | #4 |
You get what you pay for
Other than Brian's suggestions, I only wanted to add I don't care for Summit's distributors. I bought one before I got the MSD. I sent it back real quick. The one I got was junk. I never could get my engine to run right with it.
Mike 1985 Chevy C-10 |
02-29-2004, 07:11 PM | #5 |
Update: ---> Problem Solved-----> changed out Distributor.
Swervin Ervin--> is the winner !!!! Thanks Swervin !! |
02-29-2004, 07:29 PM | #6 |
When you mentioned the Summit distributor, a light came on. Although mighty dim, it still came on.
I remember the trouble I had with the one I bought. I tried everything I could to make it work. Something was wrong with the Taiwan made piece of crap. I wasn't going to buy a new distributor and start replacing stuff on it. I also wasn't going to risk sending it back for another one. This is when I bit the bullet and bought the MSD Pro-billet HEI and never looked back. Glad you found the problem and I was able to help. At least I can still win some things. |
