LS1 gas tank options
I am going to do a 5.3L LS1 swap next month and would like to find the best option for my gas tank. I want to put in under the bed and preferably have the fuel pump in the tank. I would like to know that what some others on the board have done with their fuel injection. Also for the ones that have a 4l60e transmission, what type of shifters are you using (pictures greatly appreciated)
Thanks ![]() Jerr Also I will take picts of the swap and post them if there is any interest.
1972 Chevy C-10 Short Stepside 6Cyl, 3 spd, not opts (Current Project) Now a 2004 SSR 5.3L with 4L60E Now Ididit tilt- ps, pb 2002 Saturn L200 2006 Toyota Highlander HYBRID |
Project Money Pit
What I am doing is going with a tank out of an 89 Impala. It had tbi fuel injection with the pump in the tank. I will be welding 3 inch space bars under the frame. I will then cut out a hole behind where the tag will go. Don't forget the folddown tag hinge. The gas tank neck will be shortened and fitted to be right behind the tag by using a piece of rubber hose .BTW I am using a tbi system out of an 89 van.
For sale: GMC rad support $50, L/F 69-72 fender $50, (1) 69-72 & 67-68 Chevy hood $50 ea.,1 disc brake spindles w/ calipers and rotors $ 25 WTB: (1) R/F inner fender. OR will trade Last edited by stepside71; 03-02-2004 at 01:26 AM. |
![]() Join Date: Dec 1999
Later model Blazer tank will work, though a higher pressure pump will be needed as TBI is only around 15psi I believe. I think 89-93? Mine is from a 90.
The stock linkage will work for the four speed, a little clearancing needs to be done to get it all the way into first. The guy I got my rebuilt tilt column from at the Pomona swap meet gave me a re-lettered indicator lens with the column. The lettering is a little big so I plan on redoing it with a bit of scanning, image manipulation and printing on decal media.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
Merciless Butcher
As far as the tank goes, contact board member fuellcellguy. He can hook you up with what you need.
Your Bought And Sold....I Got Your Soul! |
I think I'm going to stay with the in cab tank and put a inline external pump in the frame rail. Your pump needs close to 60psi for the LS1. I don't want to give up my spare tire mount. You'll lose it if you go with the under bed tank.
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
I'm also going to opt for the frame mounted pump. A tank mounted pump would be great, so we could reuse our lines, but it seems like its too much of a hassle to get one in there.
can't help but would like to see updates and pics.
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
![]() Join Date: Aug 2003
yesterday i saw a 68 FORD shortbed fleetside with a 5.3L VORTEC!! and 4L60e!!! he was using his factory fuel tank with an external pump, although he did have a tank from an 01 truck in the bed that he was going to throw on.
