03-04-2004, 01:28 AM | #1 |
banned for the 184th time
new trailing arm bushings pair and used coil shock brackets pair, air cleaner spacer
both parts 10 a pair plus the ride.
1. good used shape trailing arm lower shock mounting plates for C10 trucks, 2. pair of brand new trailing arm bushings with box, 3. original factory 72 350 truck 4bbl air cleaner/ carb airhorn spacer with correct PVC return port for pass side valve cover, 15 and mail 4. original painted steel pair of headlight bezels for 67 68 chevy, and also pair of same for 69-72 ones, 12 a pair plus mail email me with questions thanks Last edited by 68sr4ver; 03-04-2004 at 01:31 AM. |
03-04-2004, 03:14 PM | #2 |
Young Gun wth Fast Inline
Id also like to know zip and put in line for trailing arm bushings depending on the brand?
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
03-04-2004, 03:43 PM | #3 | |
thanks |
03-04-2004, 03:48 PM | #4 | |
the bushings are the really good ones from GMC Pauls in yerllow box i forgot brand now will have to look and see thanks Last edited by 68sr4ver; 03-04-2004 at 03:54 PM. |
03-04-2004, 07:56 PM | #5 |
What kind of shape are the headlight bezels in?
03-04-2004, 08:54 PM | #6 |
jmartin@uidaho.edu is me
03-04-2004, 10:01 PM | #7 | |
thanks |
