03-05-2004, 03:29 AM | #1 |
converting 2wd to 4wd
What would it take to make the conversion on a '72 long bed 3/4 ton?Can '73 and up parts be used or is it only possible with the same generation trucks?
03-05-2004, 05:20 AM | #2 |
huh ???
I had thought about doing the same thing. I have a doner 71 blazer for parts but after looking at the two I decided it would be eaiser to find a 4x4 truck frame. One spot on the 2x frame behind the front wheel has a dimple that would have to be flattened out so you could bore the hole for the shackel mount. You would also have to change the engine and trans crossmembers to a 4x4 style. It looked like a real PITA to me...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
03-05-2004, 11:32 AM | #3 |
I was given the drivetrain parts from a 73 blazer and thought about converting my 2wd into a 4x4 but decided the same as 72CustomCamper, it was definately possible, but not an easy conversion. It's even harder if you don't have a leaf spring frame because they are different in the back, apparently straighter rather than flared out where the read diff and coils are.
Ron
72 Chevy C10 (rust repaired, starting body work) 72 GMC 3/4ton 4x4 72 Chevy C20 Suburban 38 Ford Tudor Humpback Sedan (from the darkside) 67 Pontiac Parisienne 55 Studebaker Commander 2dr Hardtop (Starliner) My Youtube channel with Video Updates! |
03-05-2004, 12:37 PM | #4 | |
Bloo
steps to do this assuming rear leaf springs (i have no clue how to do it with rear coils):
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
