PROJECT 7DEUCE
![]() Join Date: Dec 2002
Gonna break in the new welder today I figure that I hav about 30 year's worth of hole's to weld up door handle's,marker light's ,steak pocket hole's and many other trim unused hole's to weld up... Got about 25 hole's to weld up on this door and a rocker to replace so much work I am not sure where to start..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
I welded up a bunch on my new bedside a while back. I took a piece of 1" copper tubing, about 8" long, and beat the end flat and gave it a little bend. I use that as a back up behind the hole when welding it up. Just take it nice and slow, little spot welds not long plug welds. Also use one of those 3m wheels on a grinder to remove the paint first. Enjoy!
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
![]() ![]() Truck69 ![]() ![]() |
are you completely shaving the truck? ie removing door handles and sidemarkers and all... thats what it sounds like from the first post.
70 longbed 496/th400/Ford 9" |
PROJECT 7DEUCE
Yes everything but the drip rail's will be gone roof seam gas filler cowl vent's heater box get pic's when I am done today... Later!!
When you grind the welds down use a flap wheel disc instead of a solid disc. It will make the job turn out 10 times easier.
PROJECT 7DEUCE
Yep used a flap disk and it sure made the metal work easier by not having to use filler...
PROJECT 7DEUCE
Some progress pic's from today!!!!! Finally I have made some progress as I have not touched my truck in about 2 month's due to being burnt out..
Before..
PROJECT 7DEUCE
Welded up 25 damn hole's in a door for trim and 3 set's of mirror's..
PROJECT 7DEUCE
Bed trim hole's welded up and ground smoooth..
PROJECT 7DEUCE
Mirror hole's on driver's side only had 5 hole's on this door..
PROJECT 7DEUCE
Weled up all unnessacary hole's in the dash.. Must have been about 15 different hole's for c.b. and radio e.q on the bottom side of the dash..
PROJECT 7DEUCE
Shave the inner door lock hole's...
PROJECT 7DEUCE
I know some people won't like this shot of rust free 72 door with the screw hole welded up... Gonna go with one piece glass so if anyone need's glass ,wind wing's or regulator's I woill take 60 buk's for both side's and shipping or they will hit the dumpster..
#15 |
Got Horsepower?
i'm almost finished with the trim shave and stake pocket smooth portion of my project. i only have 1 side of the bed left to do.
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit" SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers |
#16 |
AKA Phillip Johnson, AKA BANNED
I counted 21 holes on the door, not 25.. LOL. Nice job on the screw hole. 72 doors.. Ouch! They are rare!
#17 |
Merciless Butcher
The best favor anyone can do for themself is ditch the flux coated wire and pick up a bottle. It makes so much less work for yourself. Plus you get the added bonus of using thinner wire and creating less heat. I used to have a Lincoln Migpak that got ripped off. That was the biggest favor anyone ever did for me. For whoever did it, if you're out there, I owe you a beer.
Your Bought And Sold....I Got Your Soul! Last edited by gonebad2; 03-08-2004 at 05:16 AM. |
#18 |
PROJECT 7DEUCE
Gone2bad I am really happy with the miller matic 135 even though I need to build a cart as hauling the bottle around and chainng it to the truck suck's.. 71 LONGBED sure take's for ever to fill up those damn hole's huh!! Thank's for the complement's guy's...
#19 |
Out of the carpool lane.
When can you start on mine?
![]() Btw, can you send pics of the wing windows to bassmaker(at)hotmail.com
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
#20 |
I haven't started on the holes in my truck yet, been working on the Chevelle to get ready to take it to DelMar in a couple of weeks. Did get a Miller 135, also. It's great. I too have to make a cart for it, but not until after DelMar. That is, if we can afford metal by then. Priced that stuff lately?
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
#21 |
hehe you filled every hole hehe
68 short step, 406/700r4, 9" w/discs. |
#22 |
Low & Slow
it looks like you filled the little rubber bumpstop holes for the ashtray. are you going to use the ashtray still? BTW: It's looking good. I'm not too far ahead of you, I've been sitting at the point where I need to clean out the drip rail and reseal it, plus pull a hail ding out of the roof of the cab. My truck has been primed from the roof down for a few months now. I haven't went any farther because the same reason.... "burn out"
70' C-10 LWB Fleetside 4.5/6 drop ![]() Last edited by Hotrod70C10; 03-10-2004 at 04:43 AM. |
#23 |
PROJECT 7DEUCE
Hotrod70 I am gonna fill the ash tray because I don't smoke and hate having unused item's on or in my truck... Do you need an ash tray as I have the whole set-up little stiff on the sliding part if ya need it let me know..
#24 | |
Low & Slow
70' C-10 LWB Fleetside 4.5/6 drop ![]() |
#25 |
ash tray = place for change or gas receipts
