03-10-2004, 01:06 PM | #1 |
English Chevy Owner
Urgent Help with Part number
Can anybody give me a GM part number for a standard rubber transmission mount for a 67 with a 350/TH350. My UK parts supplier seem to be having trouble identifying which part I need. I made the mistake (despite advice from one or two board members, I know, I know!) of putting in an Energy Suspension poly mount and it transmits so much noise and vibration it's making my feet go numb! I'm hoping it will help them find the right one if I can give them a GM part number.
I have attached a couple of pics of the original mount, it's a bit past it's best.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
03-10-2004, 01:09 PM | #2 |
English Chevy Owner
The little tag that projects from the back of the mount wasn't hooked up to anything.
03-10-2004, 01:14 PM | #3 |
English Chevy Owner
last one
03-10-2004, 02:57 PM | #4 |
December 21, 2012
Not sure of what the GM part # might be but you should be able to track a number down from Parts America website. They list pictures of the parts. Here is just one they show for 67.
Parts America
"!Ama Sua, Ama Kjella, Ama Lllulla!" |
03-11-2004, 07:32 AM | #5 |
English Chevy Owner
Can't use that site as I don't have a zip code. I really wanted a GM part no as they may ahe a cross reference book. is there more than one mount for a TH350 equipped truck or were they all the same 67-72....Help!
03-11-2004, 08:56 AM | #6 |
F.A.S.T. president
Here is the info from that web site. The picture it shows is not the same as yours, but it could be a generic picture. I looked at one of the parts book at my shop and I dont understand what they mean by m38-3at, m40-3at. I think the M points t manual series and AT to automatic, but it really makes no sense the diffrent part numbers for the same aplication. If you know what those numbers are let me know and I will lookat the parts book again
Pic Description Availability * Price Add Anchor 2282 Engine Mount: Frt.; LH & RH 1 Year Limited Warranty Ships in 1 day Weight: 2.7 lbs. $7.79 Anchor 2378 Transmission Mount: (Incl. M38-3AT); (Incl. MT) 1 Year Limited Warranty Ships in 1 day Weight: 2.5 lbs. $6.49 Anchor 2268 Transmission Mount: M40-3AT 1 Year Limited Warranty Ships in 1 day Weight: 0.5 lbs. $7.79 |
03-11-2004, 10:11 AM | #7 | |
Works all the time Cya, Edmond
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb 1974 Chevy Camaro Z28 (Original) ------------------------- The Netherlands |
03-11-2004, 11:40 AM | #8 |
English Chevy Owner
Thanks Edmond, never thought of that! (or watched it!!)
03-11-2004, 12:27 PM | #9 |
Energy Suspension makes a poly replacement for those. I took out my rotted mount for my TH400 and got one of those. Works great, and the blue looks better than the soggy rotten black...
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
03-11-2004, 01:27 PM | #10 |
The dicontinued GM part # for the rubber th350 transmission mount is 334528. If I find a new number for it, I will post it.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
03-13-2004, 07:04 AM | #11 |
English Chevy Owner
Well, my specialist supplier came up with a part, just received it and it's an Anchor 2378 as above, so I'm guessing it's the right one, thanks for the help everyone.
